GSoC 2015: Raspberry Pi 2 Support
Alan Cudmore alan.cudmore at gmail.com
Mon Jun 22 15:27:14 UTC 2015
Great news on the Pi 2 cache configuration!
I am looking forward to a patch to try.
Alan
On Sun, Jun 21, 2015 at 3:27 PM, Rohini Kulkarni <krohini1593 at gmail.com>
wrote:
> There is very little code that had to be added.
> I need to clean the code and add conditional call for Pi 2. Then I would
> be ready to submit a patch.
>  On 22 Jun 2015 00:52, "Gedare Bloom" <gedare at gwu.edu> wrote:
>> On Sun, Jun 21, 2015 at 3:04 PM, Rohini Kulkarni <krohini1593 at gmail.com>
>> wrote:
>> > I missed mentioning the number of dhrystones in the previous mail.
>> > Originally it was 1 million.
>> > The new number of dhrystones I executed is 100 million.
>> The next thing to do is to figure out what changes are contributing to
>> the performance improvement, and then prepare patches. :) Great work
>> > On Mon, Jun 22, 2015 at 12:29 AM, Rohini Kulkarni <
>> > wrote:
>> >> Hi all,
>> >> I have managed to get a significant performance improvement with some
>> >> changes in configurations.
>> >> The measured time was for dhrystones reduced from 12 to "too small to
>> be
>> >> measured "
>> >> For dhrystones the time was 0.4.
>> >> The number of dhrystones per second increased from approximately 83333
>> to
>> >> 2500000 :)
>> >> Thanks!
>> >> On Sun, Jun 21, 2015 at 1:32 AM, Rohini Kulkarni <
>> >> wrote:
>> >>> Hi,
>> >>> I have added an SMP related post to my blog to define where exactly in
>> >>> the code I need to work. Some feedback to indicate if I am
>> identifying the
>> >>> work area correctly would be very helpful!
>> >>> Thanks!
>> >>> On 18 Jun 2015 03:37, "Rohini Kulkarni" <krohini1593 at gmail.com>
>> wrote:
>> >>>> Hi all,
>> >>>> I have updated my blog to reflect my understanding and attempts for
>> >>>> cache performance issue.
>> >>>> Lately I have been trying around memory attributes for the
>> >>>> mm_config_table. One set of configurations for cacheable memory
>> (inner and
>> >>>> outer levels)ended up reducing performance further ( which I really
>> thought
>> >>>> would improve). So this table set up certainly controls performance.
>> >>>> The results are not improving after turning on cache. So memory
>> sections
>> >>>> are perhaps not even getting cached.
>> >>>> I get a feeling it has got to do with this mm_config_table.
>> >>>> Updates from the github code and blog might help in further
>> discussion.
>> >>>> Link to github code:https://github.com/krohini1593/rtems/tree/rohini
>> >>>> Link to Blog
>> >>>> Thanks!
>> >>>> On Mon, Jun 15, 2015 at 8:29 PM, Alan Cudmore <
>> alan.cudmore at gmail.com>
>> >>>> wrote:
>> >>>>> Hi,
>> >>>>> Some of the code examples may give you some clues. Like this one:
>> >>>>> https://github.com/mrvn/test/blob/master/smp.cc
>> >>>>> Or this:
>> >>>>> https://github.com/PeterLemon/RaspberryPi/tree/master/SMP/SMPINIT
>> >>>>> If you still can't figure it out, you can always join the
>> >>>>> raspberrypi.org forums and ask on this thread:
>> >>>>> https://www.raspberrypi.org/forums/viewtopic.php?f=72&t=98904
>> >>>>> When it comes to the Pi 2 and SMP, you are our RTEMS expert :)
>> >>>>> Thanks,
>> >>>>> Alan
>> >>>>> On Sat, Jun 13, 2015 at 2:29 PM, Rohini Kulkarni
>> >>>>> <krohini1593 at gmail.com> wrote:
>> >>>>>> Hi,
>> >>>>>> This is regarding Pi 2 SMP support. After powering on, the
>> secondary
>> >>>>>> mailboxes read one of their four mailbox registers and wait for a
>> non-zero
>> >>>>>> content to be written. This content is to be the physical address
>> of the
>> >>>>>> location from where the cores are expected to start execution.
>> >>>>>> I am stuck at figuring out this address. How should I go about
>> >>>>>> understanding this?
>> >>>>>> Thanks!
>> >>>>>> On 3 Jun 2015 19:44, "Gedare Bloom" <gedare at gwu.edu> wrote:
>> >>>>>>> On Wed, Jun 3, 2015 at 2:39 AM, Rohini Kulkarni
>> >>>>>>> > But, I can't say cache configurations have a role here.
>> >>>>>>> > I'll push my code to my github project soon.
>> >>>>>>> > P.S. The Pi2 board I possess seems to have broken down. It just
>> >>>>>>> > isn't
>> >>>>>>> > turning on. Unable to test further. Will order one immediately.
>> >>>>>>> Ouch. Make sure you put it in a safe space for development, clear
>> of
>> >>>>>>> threats like moisture, static shock, and cats.
>> >>>>>>> > On 3 Jun 2015 09:03, "Rohini Kulkarni" <krohini1593 at gmail.com>
>> >>>>>>> > wrote:
>> >>>>>>> >> Hi,
>> >>>>>>> >> Alan, your suggestion has resulted in much improvement
>> >>>>>>> >> arm_control=0x1000
>> >>>>>>> >> This has simply worked! Looks like the other cores were taking
>> up
>> >>>>>>> >> plenty
>> >>>>>>> >> of time.
>> >>>>>>> >> I was aware from references that the other cores run a WFI, but
>> >>>>>>> >> ya, did
>> >>>>>>> >> not get its impact.
>> >>>>>>> >> Time for each dhrystone has reduced to 7 from 13 and the no of
>> >>>>>>> >> dhrystones
>> >>>>>>> >> per second also increased.
>> >>>>>>> >> But this is a change only in the config.txt not actually in the
>> >>>>>>> >> boot code.
>> >>>>>>> >> Thanks
>> >>>>>>> >> Rohini
>> >>>>>>> >> On Wed, Jun 3, 2015 at 7:12 AM, Alan Cudmore
>> >>>>>>> >> <alan.cudmore at gmail.com>
>> >>>>>>> >> wrote:
>> >>>>>>> >>> The caches are being enabled on the RPI 1 BSP. The same code
>> is
>> >>>>>>> >>> being
>> >>>>>>> >>> executed by the RPI 2 BSP, but obviously it’s not sufficient
>> for
>> >>>>>>> >>> the cache
>> >>>>>>> >>> setup.
>> >>>>>>> >>> I have been reading through this long thread, and it is very
>> >>>>>>> >>> informative:
>> >>>>>>> >>> I am starting to understand the setup that is required to
>> enable
>> >>>>>>> >>> caches
>> >>>>>>> >>> on the RPI 2. For example this message near the bottom of
>> page 3
>> >>>>>>> >>> gives a
>> >>>>>>> >>> good indication of the speedup available by configuring the
>> MMU
>> >>>>>>> >>> and caches
>> >>>>>>> >>> correctly:
>> >>>>>>> >>> Quote from above thread
>> >>>>>>> >>> Enabling I/D caches and branch prediction, just like the julia
>> >>>>>>> >>> demo uses,
>> >>>>>>> >>> it takes ~12 seconds, or ~21 fps. It's just one core but also
>> a
>> >>>>>>> >>> much smaller
>> >>>>>>> >>> loop than the julia demo has.
>> >>>>>>> >>> Enabling the MMU and mapping memory inner/outer write-back,
>> write
>> >>>>>>> >>> allocate and the framebuffer inner write-through, no write
>> >>>>>>> >>> allocate + outer
>> >>>>>>> >>> write-back, write-allocate it takes ~8 seconds, of 32 fps.
>> >>>>>>> >>> PS: 640x480x32 with MMU gets me ~256 fps. Must have a greater
>> L2
>> >>>>>>> >>> cache
>> >>>>>>> >>> effect.
>> >>>>>>> >>> End of quote
>> >>>>>>> >>> The person who posted the above comment (mrvn) posted the code
>> >>>>>>> >>> here:
>> >>>>>>> >>> https://github.com/mrvn/test/blob/master/mmu.cc
>> >>>>>>> >>> Also, it seems that when the Pi 2 starts up, cores 1-3 are
>> put in
>> >>>>>>> >>> a wait
>> >>>>>>> >>> loop always accessing the bus. By putting this option in the
>> >>>>>>> >>> config.txt file
>> >>>>>>> >>> you can put the other cores to sleep, speeding up the code on
>> >>>>>>> >>> core 1.
>> >>>>>>> >>>  arm_control=0x1000
>> >>>>>>> >>> It would be worth trying that option to see if the benchmark
>> >>>>>>> >>> speeds up.
>> >>>>>>> >>> Alan
>> >>>>>>> >>> On Jun 2, 2015, at 8:05 AM, Hesham ALMatary
>> >>>>>>> >>> <heshamelmatary at gmail.com>
>> >>>>>>> >>> wrote:
>> >>>>>>> >>> On Tue, Jun 2, 2015 at 12:41 PM, Rohini Kulkarni
>> >>>>>>> >>> wrote:
>> >>>>>>> >>> From what I saw, they have to be enabled separately. Cache/mmu
>> >>>>>>> >>> are
>> >>>>>>> >>> disabled
>> >>>>>>> >>> upon reset.
>> >>>>>>> >>> For the existing Raspberry BSP [1] there's a code for
>> MMU/Cache
>> >>>>>>> >>> init,
>> >>>>>>> >>> however I don't know about Pi2 and where its code is.
>> >>>>>>> >>> [1]
>> https://github.com/RTEMS/rtems/tree/master/c/src/lib/libbsp/arm/raspberrypi
>> >>>>>>> >>> On 2 Jun 2015 16:59, "Hesham ALMatary" <
>> >>>>>>> >>> wrote:
>> >>>>>>> >>> Hi,
>> >>>>>>> >>> Aren't the MMU/Caches enabled by default for RPi [1]?
>> >>>>>>> >>> [1]
>> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
>> >>>>>>> >>> On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
>> >>>>>>> >>> <joel.sherrill at oarcorp.com> wrote:
>> >>>>>>> >>> On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni
>> >>>>>>> >>> wrote:
>> >>>>>>> >>> Dr. Joel,
>> >>>>>>> >>> So we can't say something solely on the basis of this result?
>> >>>>>>> >>> I don't think so. If Linux performs the same, then what you
>> did
>> >>>>>>> >>> is as
>> >>>>>>> >>> good as it gets.
>> >>>>>>> >>> However, if Linux is faster then some setting still isn't
>> right.
>> >>>>>>> >>> You need a reference measurement to have any confidence. It is
>> >>>>>>> >>> possible
>> >>>>>>> >>> you did something but didn't actually turn the cache (or all
>> the
>> >>>>>>> >>> cache)
>> >>>>>>> >>> on.
>> >>>>>>> >>> On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com
>> >>>>>>> >>> wrote:
>> >>>>>>> >>> I have not run it under linux on pi2 yet. Will have to run and
>> >>>>>>> >>> check
>> >>>>>>> >>> the result.
>> >>>>>>> >>> On 2 Jun 2015 16:16, "Joel Sherrill" <
>> >>>>>>> >>> wrote:
>> >>>>>>> >>> On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni
>> >>>>>>> >>> wrote:
>> >>>>>>> >>> HI,
>> >>>>>>> >>> I tried running the dhrystone benchmark with some changes for
>> >>>>>>> >>> cache/mmu
>> >>>>>>> >>> set up.
>> >>>>>>> >>> However, the output shows a reduction in performance.
>> >>>>>>> >>> The time to run through the dhrystone has increased from 12
>> to 13
>> >>>>>>> >>> and
>> >>>>>>> >>> dhrystones run per second decreased.
>> >>>>>>> >>> According to this result, things were better with caches
>> >>>>>>> >>> disabled.
>> >>>>>>> >>> I have been working on this since two days and could not
>> figure
>> >>>>>>> >>> out an
>> >>>>>>> >>> improvement. Any pointers?
>> >>>>>>> >>> How did it do under Linux on the Pi2?
>> >>>>>>> >>> Thanks.
>> >>>>>>> >>> On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
>> >>>>>>> >>> Hi All,
>> >>>>>>> >>> I have to implement the cache coherency support for Cortex A7.
>> >>>>>>> >>> But for
>> >>>>>>> >>> A7 MPCore, unlike for A9, I am not able to find any register
>> >>>>>>> >>> description for the Snoop Control Unit from the TRM.
>> >>>>>>> >>> I need help here on how to proceed.
>> >>>>>>> >>> Additionally for A9 there is a single bit for A9 in the
>> Auxiliary
>> >>>>>>> >>> Control Register which enables cache broadcast operations. The
>> >>>>>>> >>> register
>> >>>>>>> >>> format is different for A7 and again I am unable to find how
>> to
>> >>>>>>> >>> achieve
>> >>>>>>> >>> the same for A7.
>> >>>>>>> >>> Thanks!
>> >>>>>>> >>> On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
>> >>>>>>> >>> On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
>> >>>>>>> >>> Hi,
>> >>>>>>> >>> I am working with the code for bsp hooks. I am referring to
>> >>>>>>> >>> existing
>> >>>>>>> >>> ARM multicore bsp codes, zync mainly.
>> >>>>>>> >>> 1. There are existing hooks for the raspberry pi. Where should
>> >>>>>>> >>> the
>> >>>>>>> >>> code
>> >>>>>>> >>> for the  Pi2 hooks be added?
>> >>>>>>> >>> The Pi and Pi2 are remarkably similar so Pi2 should be placed
>> >>>>>>> >>> inside
>> >>>>>>> >>> the Pi BSP directory.
>> >>>>>>> >>> There is already a Pi2 variant of that code built. But we know
>> >>>>>>> >>> specific
>> >>>>>>> >>> places where there
>> >>>>>>> >>> are variances. Depending on the scope of what is different, it
>> >>>>>>> >>> can be
>> >>>>>>> >>> as simple as
>> >>>>>>> >>> a cpp conditional in a .h to select a value or two
>> >>>>>>> >>> implementations of
>> >>>>>>> >>> a
>> >>>>>>> >>> single method
>> >>>>>>> >>> and the Makefile.am picking the right file to build based on
>> the
>> >>>>>>> >>> board
>> >>>>>>> >>> variant.
>> >>>>>>> >>> The big question to always ask is: Is this specific to the Pi2
>> >>>>>>> >>> and
>> >>>>>>> >>> incompatible with the Pi?
>> >>>>>>> >>> Since the Pi BSP is still missing capabilities, it is likely
>> code
>> >>>>>>> >>> common to both will
>> >>>>>>> >>> be added this summer. For example, did the mailbox interface
>> >>>>>>> >>> change? I
>> >>>>>>> >>> don't know
>> >>>>>>> >>> but would guess that it didn't.  Each new capability added
>> needs
>> >>>>>>> >>> that
>> >>>>>>> >>> added.
>> >>>>>>> >>> And any differences need to be analyzed to pick the least
>> >>>>>>> >>> intrusive
>> >>>>>>> >>> way
>> >>>>>>> >>> to provide
>> >>>>>>> >>> alternate implementations. Or enable special code like the Pi2
>> >>>>>>> >>> SMP
>> >>>>>>> >>> support which
>> >>>>>>> >>> is dependent on --enable-smp and being a Pi2.
>> >>>>>>> >>> 2. Am I right in understanding that I will have to implement
>> A7
>> >>>>>>> >>> specific functions as have been for A9? I am referring
>> >>>>>>> >>> specifically to
>> >>>>>>> >>> the arm-a9mpcore-start.h
>> >>>>>>> >>> Yes.
>> >>>>>>> >>> If the code is very similar between the a7 and a9, then a
>> >>>>>>> >>> discussion
>> >>>>>>> >>> on devel@ should occur to decide the best way to minimize
>> >>>>>>> >>> duplication.
>> >>>>>>> >>> If you end up with a7 specific code, you should follow the
>> >>>>>>> >>> location
>> >>>>>>> >>> and
>> >>>>>>> >>> naming patterns already established. That places it in
>> >>>>>>> >>> libbsp/arm/shared/...
>> >>>>>>> >>> so it can be used by any BSP with the right SMP core.
>> >>>>>>> >>> I am referring to existing codes to locate and get hold of
>> what
>> >>>>>>> >>> needs
>> >>>>>>> >>> to be done in the hooks. However, being new to such
>> >>>>>>> >>> implementations, I
>> >>>>>>> >>> am taking longer to understand the details. Any suggestions
>> that
>> >>>>>>> >>> might
>> >>>>>>> >>> help here are welcome
>> >>>>>>> >>> The answer will depend on the factors listed above. When code
>> can
>> >>>>>>> >>> be shared, we want to share it across as many BSPs as makes
>> >>>>>>> >>> sense.
>> >>>>>>> >>> When it is unique to a specific BSP **variant** (e.g. Pi vs
>> Pi2),
>> >>>>>>> >>> then
>> >>>>>>> >>> you want to find the way to account for the variation in the
>> >>>>>>> >>> least
>> >>>>>>> >>> intrusive code way possible.
>> >>>>>>> >>> Thanks!
>> >>>>>>> >>> On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com
>> >>>>>>> >>> wrote:
>> >>>>>>> >>> Hi,
>> >>>>>>> >>> Excited to be a part of  this edition of GSoC! Thanks to
>> >>>>>>> >>> everybody for
>> >>>>>>> >>> helping me get here and congratulations to all the
>> participating
>> >>>>>>> >>> students!
>> >>>>>>> >>> So, now getting to work, firstly I wish to know, specifically
>> >>>>>>> >>> from my
>> >>>>>>> >>> mentors, any changes that must be made to my proposed project
>> or
>> >>>>>>> >>> schedule.
>> >>>>>>> >>> Secondly, are there any specifics for the development blog
>> that
>> >>>>>>> >>> we
>> >>>>>>> >>> need
>> >>>>>>> >>> to create for the project? Over time what is the blog
>> expected to
>> >>>>>>> >>> convey.
>> >>>>>>> >>> Also, I have to create a new wiki page for my project as none
>> >>>>>>> >>> exists.
>> >>>>>>> >>> I
>> >>>>>>> >>> want to know how to add one.
>> >>>>>>> >>> Rohini Kulkarni
>> >>>>>>> >>> -- Joel Sherrill, Ph.D. Director of Research & Development
>> >>>>>>> >>> joel.sherrill at OARcorp.com On-Line Applications Research Ask
>> me
>> >>>>>>> >>> about
>> >>>>>>> >>> RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
>> >>>>>>> >>> 722-9985
>> >>>>>>> >>> Rohini Kulkarni
>> >>>>>>> >>> Rohini Kulkarni
>> >>>>>>> >>> --joel
>> >>>>>>> >>> --joel
>> >>>>>>> >>> _______________________________________________
>> >>>>>>> >>> devel mailing list
>> >>>>>>> >>> devel at rtems.org
>> >>>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>> >>>>>>> >>> Hesham
>> >>>>>>> >>> Hesham
>> >>>>>>> >>> devel mailing list
>> >>>>>>> >>> devel at rtems.org
>> >>>>>>> >> Rohini Kulkarni
>> >>>>>>> > devel mailing list
>> >>>>>>> > devel at rtems.org
>> >>>>>> devel mailing list
>> >>>>>> devel at rtems.org
>> >>>> Rohini Kulkarni
>> >> Rohini Kulkarni
>> > Rohini Kulkarni
>> > devel mailing list
>> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150622/ae0f023a/attachment-0002.html>
