GSOC 2015: Configuration GUI
Anand Krishnan anandkp92 at gmail.com
Sat Jun 27 01:46:35 UTC 2015
Hi,
The GUI is partially done. The set up for Boolean and Integer options is
done.
Find the files here: https://github.com/anandkp92/waf/tree/waf/gui
[Run gui.py].
Please let me know if you are facing any issue while running this file or
any changes I have to make.
Thanks,
Anand
On Thu, Jun 18, 2015 at 12:07 PM, Anand Krishnan <anandkp92 at gmail.com>
wrote:
> Hi,
> On Thu, Jun 18, 2015 at 10:45 AM, Anand Krishnan <anandkp92 at gmail.com>
> wrote:
>> On Thu, Jun 18, 2015 at 6:18 AM, Amar Takhar <amar at rtems.org> wrote:
>>> On 2015-06-18 05:57 +0530, Anand Krishnan wrote:
>>> > Hi all,
>>> > I've almost prepared the basic layout for the GUI. Also added some
>>> dummy event
>>> > handlers for File Menu.
>>> > Any more suggestions before fetching the options?
>>> This is a great start!
>>> Have you thought about how you are going to lay out the tabs for
>>> multiple BSP
>>> configs + the tag headings?
>>> One option is to do multi-layered tabs along the top.  Another is tabs
>>> on the
>>> top and vertically (left side).
>>> I'll check it out now and post it when I get some good  results
> I've added the multilayered tabs. I tried both the ways that you mentioned
> -> along the top and left. And I felt this was better. But I can revert to
> the other one in no time.
> link: https://github.com/anandkp92/waf/tree/waf/gui
>>> Amar.
>> Thanks,
>> Anand
> Anand.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150627/2b1483df/attachment-0002.html>
