25% PowerPC code size increase since last September?
    Gedare Bloom
    gedare at gwu.edu
    Mon Jun 29 13:52:38 UTC 2015
On Sun, Jun 28, 2015 at 11:05 AM, Peter Dufault <dufault at hda.com> wrote:
> In updating the Phytec MPC5554 to this mornings build I see a large code size increase.  It will no longer fit in the 2MB FLASH on the MPC5554, which is a problem.  Here are the sizes of the binaries, the first one built two days ago against the RTEMS in September and the second one using the identical user code base and this morning’s RTEMS.  I haven’t done much to analyze this yet other than to verify it’s still being built with the same optimization flags.
> -rwxrwxr-x 1 pjd usergrp 1624684 Jun 26 09:42 fw.bin.gcc4.8.2
> -rwxrwxr-x 1 pjd usergrp 2017220 Jun 28 10:48 fw.bin
> Has anyone else noticed this?  Does anyone regularly monitor the size of the test suite binaries to watch for changes?  Are there new options that should be set to disable new features that add size overhead?
Monitoring the size of the binaries would probably be a good thing to
do especially with buildbot when that gets working.
