New source layout.
Amar Takhar amar at rtems.org
Sat Mar 7 01:20:46 UTC 2015
The following is a proposal for a new source layout that will be included in the
new 'waf' build system.  The current layout is a product of years of laying and
requirements for the auto* build system.  Since we are no longer restricted by
this it makes sense to take the time and give RTEMS a more sensible source
layout.
rtems/bsp/* exists to carry common bsp files.  I don't know why it makes sense
to have score/* then cpu/* with separate architectures.  Even if the purpose is
different does it make sense to have two completely separate areas with
architecture hierarchies?  There may have been a reason to do this before is
there one now?
There are some interdependencies between the common BSP files (bsp.h).  I can
hack around this for now using waf until we can break this interdependency by
moving to public APIs.
Note: the reason for rtems/bsp/* existing is to unhook rtems/ and bsp/ 100%.
This means you can develop a BSP with only librtems installed on your system and
nothing else.  We will also support a build that does not build any BSP code.
It will also allow us to split our tests correctly as well.
I will propose a 1:1 mapping of all source and header files from current -> new
location for approval once we have the general layout completed.  I would like
to avoid renaming the source files themselves until after we have moved and
verified everything builds OK.  Renaming the files in-dir is a trivial
operation and can be verified using a hash of the resulting libraries.
include locations
include/rtems/include/             - Private API
include/rtems/include/rtems/       - Public API
include/rtems/bsp/include/         - Common BSP files
include/rtems/bsp/include/<arch>   - Architecture specific
rtems/lib/ada/          [c/src/ada]
rtems/lib/block
rtems/lib/csupport
rtems/lib/fs
rtems/lib/misc
rtems/lib/networking
rtems/lib/rpc
rtems/lib/z
rtems/lib/qos
rtems/lib/md
rtems/lib/gnat
rtems/lib/i2c
rtems/lib/rtems++       [c/src/librtems++]
rtems/classic           [cpukit/rtems]
rtems/posix
rtems/sapi
rtems/server/ftpd
rtems/server/mghttpd
rtems/server/pppd
rtems/score
The following need to be discussed in detail as they will end up split into multiple locations:
rtems/bsp/chip/         [c/src/libchip]
rtems/bsp/shared/<arch> [c/src/lib/libcpu]
Note: c/src/support has been killed.
bsp (contents of c/src/lib/libbsp, actual BSP source)
bsp/<arch>/
bsp/<arch>/<bsp>/
bsp/<arch>/<bsp>/include <-installable BSP headers.
installed locations
include/rtems/bsp/              - Common BSP files
include/rtems/bsp/<arch>/       - Architecture specific
include/rtems/bsp/<arch/<bsp>/  - BSP specific
changes to source
- All RTEMS source will use #include <rtems/header.h> for public API
- Private API will use #include "header.h"
- Local header will use #include "header.h"
- Only -Iinclude will be provided all paths must be full and start with 'rtems/'
  to avoid name clashing and for clarity.
Please feel free to comment on any of the above.  It is meant as a guideline for
us to talk about the larger 'chunks' of source.  Eventually this will move to a
spreadsheet that contains 1:1 mapping of old_dir -> new_dir locations.
Amar.
