Serious Doxygen Warnings
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Mar 9 18:43:21 UTC 2015
Hi
Most Doxygen warnings indicate we haven't documented something
yet but the following indicate something is structurally wrong with
the markup or ifdef's. It would be appreciated if these could be
addressed. If no patch shows up shortly, I will file individual PRs
on each file:
/data/docs/build/b-doc/sparc-rtems4.11/leon3/lib/include/dev/i2c/i2c.h:431: warning: end of file while inside a group
/data/docs/build/b-doc/sparc-rtems4.11/leon3/lib/include/rtems/capture.h:988: warning: end of file while inside a group
/data/docs/build/b-doc/sparc-rtems4.11/leon3/lib/include/rtems/devfs.h:257: warning: reached end of file while inside a code block!
The command that should end the block seems to be missing!
/data/docs/build/b-doc/sparc-rtems4.11/leon3/lib/include/rtems/devfs.h:257: warning: end of file while inside a group
/data/docs/build/b-doc/sparc-rtems4.11/leon3/lib/include/rtems/fsmount.h:233: warning: More #endif's than #if's found.
/data/docs/build/b-doc/sparc-rtems4.11/leon3/lib/include/rtems/score/todimpl.h:121: warning: group ScoreTOD: ignoring title "Time Of Day (TOD) Handler" that does not match old title "Time of Day Handler"
/data/docs/build/b-doc/sparc-rtems4.11/leon3/lib/include/rtems/score/scheduleredfimpl.h:29: warning: group ScoreSchedulerEDF: ignoring title "EDF" that does not match old title "EDF Scheduler"
