[PATCH] posix/src/nanosleep.c: Address issue when delay is longer than desired
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Mar 11 21:20:30 UTC 2015
This resulted in the elapsed time going below 0 and an arbitrarily large
number returned as the time remaining.
closes #2296.
cpukit/posix/src/nanosleep.c | 43 +++++++++++++++++++++++++++----------------
1 file changed, 27 insertions(+), 16 deletions(-)
diff --git a/cpukit/posix/src/nanosleep.c b/cpukit/posix/src/nanosleep.c
index 1fbeaa3..39ae84d 100644
--- a/cpukit/posix/src/nanosleep.c
+++ b/cpukit/posix/src/nanosleep.c
@@ -1,12 +1,12 @@
* @file
- * @brief Suspends Execution of calling thread until Time elaps
+ * @brief Suspends Execution of calling thread until Time elapses
* @ingroup POSIXAPI
- * COPYRIGHT (c) 1989-2007.
+ * COPYRIGHT (c) 1989-2015.
* On-Line Applications Research Corporation (OAR).
* The license and distribution terms for this file may be
@@ -29,7 +29,6 @@
* 14.2.5 High Resolution Sleep, P1003.1b-1993, p. 269
int nanosleep(
const struct timespec *rqtp,
struct timespec *rmtp
@@ -42,6 +41,7 @@ int nanosleep(
Thread_Control *executing;
Watchdog_Interval ticks;
+ Watchdog_Interval elapsed;
@@ -53,6 +53,9 @@ int nanosleep(
if ( !_Timespec_Is_valid( rqtp ) )
rtems_set_errno_and_return_minus_one( EINVAL );
+ * Convert the timespec delay into the appropriate number of clock ticks.
ticks = _Timespec_To_ticks( rqtp );
@@ -60,7 +63,6 @@ int nanosleep(
* This behavior is also beyond the POSIX specification but is
* consistent with the RTEMS API and yields desirable behavior.
if ( !ticks ) {
_Thread_Disable_dispatch();
executing = _Thread_Executing;
@@ -91,24 +93,33 @@ int nanosleep(
_Watchdog_Insert_ticks( &executing->Timer, ticks );
_Thread_Enable_dispatch();
- /* calculate time remaining */
+ * Calculate the time that passed while we were sleeping and how
+ * much remains from what we requested.
+ elapsed = executing->Timer.stop_time - executing->Timer.start_time;
+ if ( elapsed >= ticks )
+ ticks = 0;
+ else
+ ticks -= elapsed;
+ * If the user wants the time remaining, do the conversion.
if ( rmtp ) {
- ticks -= executing->Timer.stop_time - executing->Timer.start_time;
_Timespec_From_ticks( ticks, rmtp );
+ * Only when POSIX is enabled, can a sleep be interrupted.
+ #if defined(RTEMS_POSIX_API)
- * Only when POSIX is enabled, can a sleep be interrupted.
+ * If there is time remaining, then we were interrupted by a signal.
- #if defined(RTEMS_POSIX_API)
- * If there is time remaining, then we were interrupted by a signal.
- if ( ticks )
- rtems_set_errno_and_return_minus_one( EINTR );
- #endif
+ if ( ticks )
+ rtems_set_errno_and_return_minus_one( EINTR );
+ #endif
return 0;
1.9.3
