problem when runing rpi sample on gdb simu
QIAO YANG
yangqiao0505 at me.com
Thu Mar 12 01:42:20 UTC 2015
Hello ,
I was wondering if the raspberry pi samples can run on arm-rtems4.11-gdb. I thought I had done the compilations correctly according to Mr Alan's blog, but it just stand still when running the sample in the simulator.
I'm not sure if it's my problem or it can only run on a real rpi board. If it's my own problem I'll double check what I've done, if not I've got to wait until next week to post my hello demo when the cable arrives.
here's the output of gdb:
Reading symbols from ./arm-rtems4.11/c/raspberrypi/testsuites/samples/hello/hello.exe...done.
(gdb) tar sim
Connected to the simulator.
(gdb) load
Loading section .start, size 0x340 vma 0x8000
Loading section .text, size 0x17920 vma 0x8340
Loading section .init, size 0x18 vma 0x1fc60
Loading section .fini, size 0x18 vma 0x1fc78
Loading section .rodata, size 0xc30 vma 0x100000
Loading section .ARM.exidx, size 0x8 vma 0x100c30
Loading section .eh_frame, size 0x48 vma 0x100c38
Loading section .init_array, size 0x4 vma 0x100c80
Loading section .fini_array, size 0x4 vma 0x100c84
Loading section .jcr, size 0x4 vma 0x100c88
Loading section .data, size 0x5e8 vma 0x100c90
Start address 0x8040
Transfer rate: 817184 bits in <1 sec.
(gdb) r
Starting program: /home/yangqiao/development/rtems/build-rtems-rpi/arm-rtems4.11/c/raspberrypi/testsuites/samples/hello/hello.exe
Best regards,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150312/c12a6f7f/attachment.html>
