Detecting Tests Which Don't Have Enough Workspace
Gedare Bloom gedare at gwu.edu
Thu Mar 12 17:45:47 UTC 2015
On Thu, Mar 12, 2015 at 1:41 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> Many BSPs can link a test but don't actually have enough memory
> to run the test. They will fail in the first few lines when the requested
> memory for the RTEMS work area is not available. I hacked together
> a script which adds together the code, data, bss, work space and
> stack space requested. If this exceeds physical memory on the board,
> then the test will fail.  It is possible to come close and still run out of
> memory during initialization (e.g. malloc, etc) but this approach could
> detect some tests which will fail by inspecting them on the host.
> This is a shell script but would be better built into the rtems-tools
> and using the gdb/mi. Combined with information on the
> available memory on the target, we could throw out some obvious
> failure cases without touching hardware.
> Thoughts?
Would it be worthwhile to instrument our build (post-link) to do
something like this?
> #! /bin/sh
> if [ $# -le 2 ] ; then
>   echo "Usage: $0 ARCH EXE ..."
>   exit 1
> fi
> ARCH=$1
> shift
> target=${ARCH}-rtems4.11
> type ${ARCH}-rtems4.11-size >/dev/null 2>&1
> if [ $? -ne 0 ] ; then
>   echo "${ARCH} does not appear to have RTEMS 4.11 tools installed"
>   exit 1
> fi
> extract_size()
>   ( echo "p Configuration.work_space_size" ; \
>     echo "quit" ) | ${target}-gdb ${exe} 2>&1 | grep "\$1" | \
>   cut -d'=' -f2
> for exe in $*
> do
>  image_size=`${target}-size ${exe} | tail -1 | cut -f4`
>  wkspace_size=`extract_size Configuration.work_space_size`
>  stackspace_size=`extract_size Configuration.stack_space_size`
>  #echo ${image_size} ${wkspace_size} ${stackspace_size}
>  total=`echo ${image_size} ${wkspace_size} + ${stackspace_size} + p | dc`
>  echo ${total} ${exe}
> done
> exit 0
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
