[PATCH v3] Merge parts of <sys/time.h> from FreeBSD
Sebastian Huber
Fri Mar 13 10:00:39 UTC 2015
Merge parts of the latest <sys/time.h> from FreeBSD to Newlib. This has
two reasons.
1. We want to use the FreeBSD timecounters for timekeeping in RTEMS.
See also https://devel.rtems.org/ticket/2271.
2. This makes the port of the network stack from FreeBSD easier.
newlib/ChangeLog
2015-03-12 Sebastian Huber <sebastian.huber at embedded-brains.de>
* libc/include/machine/_types.h (__suseconds_t): Define.
* libc/include/sys/_timeval.h: Import from FreeBSD and add
MinGW-w64 compatibility.
(timerclear): Copy from FreeBSD <sys/time.h>.
(timerisset): Likewise.
(timercmp): Likewise.
(timeradd): Likewise.
(timersub): Likewise.
* libc/include/sys/time.h: (bintime, ...) Import from FreeBSD.
(timespecclear, ...): Likewise.
(inittodr, ...): Likewise.
(timerclear): Delete.
(futimes): Declare if __BSD_VISIBLE.
(futimesat): Likewise.
(lutimes): Likewise.
(setitimer): Declare unconditionally.
(gettimeofday): Declare if __XSI_VISIBLE.
* libc/include/sys/types.h (sbintime_t): Define.
(suseconds_t): Define conditionally via __suseconds_t.
newlib/libc/include/machine/types.h | 2 +
newlib/libc/include/sys/_timeval.h | 88 +++++++
newlib/libc/include/sys/time.h | 480 +++++++++++++++++++++++++++++++-----
newlib/libc/include/sys/types.h | 8 +-
4 files changed, 513 insertions(+), 65 deletions(-)
create mode 100644 newlib/libc/include/sys/_timeval.h
diff --git a/newlib/libc/include/machine/types.h b/newlib/libc/include/machine/types.h
index 40a75fa..4250ee3 100644
--- a/newlib/libc/include/machine/types.h
+++ b/newlib/libc/include/machine/types.h
@@ -25,6 +25,8 @@ typedef long int __loff_t;
#endif
#endif
+typedef long __suseconds_t; /* microseconds (signed) */
#endif /* _MACHTYPES_H_ */
diff --git a/newlib/libc/include/sys/_timeval.h b/newlib/libc/include/sys/_timeval.h
new file mode 100644
index 0000000..0a4c539
--- /dev/null
+++ b/newlib/libc/include/sys/_timeval.h
@@ -0,0 +1,88 @@
+ * Copyright (c) 2002 Mike Barcroft <mike at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _SYS__TIMEVAL_H_
+#define _SYS__TIMEVAL_H_
+#include <machine/types.h>
+#ifndef _SUSECONDS_T_DECLARED
+typedef __suseconds_t suseconds_t;
+#define _SUSECONDS_T_DECLARED
+#endif
+#ifndef __time_t_defined
+typedef _TIME_T_ time_t;
+#define __time_t_defined
+#endif
+/* This define is also used outside of Newlib, e.g. in MinGW-w64 */
+#ifndef _TIMEVAL_DEFINED
+#define _TIMEVAL_DEFINED
+ * Structure returned by gettimeofday(2) system call, and used in other calls.
+struct timeval {
+ time_t tv_sec; /* seconds */
+ suseconds_t tv_usec; /* and microseconds */
+#if __BSD_VISIBLE
+#ifndef _KERNEL /* NetBSD/OpenBSD compatible interfaces */
+#define timerclear(tvp) ((tvp)->tv_sec = (tvp)->tv_usec = 0)
+#define timerisset(tvp) ((tvp)->tv_sec || (tvp)->tv_usec)
+#define timercmp(tvp, uvp, cmp) \
+ (((tvp)->tv_sec == (uvp)->tv_sec) ? \
+ ((tvp)->tv_usec cmp (uvp)->tv_usec) : \
+ ((tvp)->tv_sec cmp (uvp)->tv_sec))
+#define timeradd(tvp, uvp, vvp) \
+ do { \
+ (vvp)->tv_sec = (tvp)->tv_sec + (uvp)->tv_sec; \
+ (vvp)->tv_usec = (tvp)->tv_usec + (uvp)->tv_usec; \
+ if ((vvp)->tv_usec >= 1000000) { \
+ (vvp)->tv_sec++; \
+ (vvp)->tv_usec -= 1000000; \
+ } while (0)
+#define timersub(tvp, uvp, vvp) \
+ do { \
+ (vvp)->tv_sec = (tvp)->tv_sec - (uvp)->tv_sec; \
+ (vvp)->tv_usec = (tvp)->tv_usec - (uvp)->tv_usec; \
+ if ((vvp)->tv_usec < 0) { \
+ (vvp)->tv_sec--; \
+ (vvp)->tv_usec += 1000000; \
+ } while (0)
+#endif
+#endif /* __BSD_VISIBLE */
+#endif /* _TIMEVAL_DEFINED */
+#endif /* !_SYS__TIMEVAL_H_ */
diff --git a/newlib/libc/include/sys/time.h b/newlib/libc/include/sys/time.h
index 470a1a6..4a34293 100644
--- a/newlib/libc/include/sys/time.h
+++ b/newlib/libc/include/sys/time.h
@@ -2,91 +2,443 @@
Written by Geoffrey Noer <noer at cygnus.com>
Public domain; no rights reserved. */
+ * Copyright (c) 1982, 1986, 1993
+ * The Regents of the University of California. All rights reserved.
+ * are met:
+ * 4. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * SUCH DAMAGE.
+ * @(#)time.h 8.5 (Berkeley) 5/4/95
+ * $FreeBSD$
#ifndef _SYS_TIME_H_
-#define _SYS_TIME_H_
+#define _SYS_TIME_H_
#include <_ansi.h>
-#include <sys/cdefs.h>
+#include <sys/_timeval.h>
#include <sys/types.h>
+#include <sys/timespec.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
+struct timezone {
+ int tz_minuteswest; /* minutes west of Greenwich */
+ int tz_dsttime; /* type of dst correction */
+#define DST_NONE 0 /* not on dst */
+#define DST_USA 1 /* USA style dst */
+#define DST_AUST 2 /* Australian style dst */
+#define DST_WET 3 /* Western European dst */
+#define DST_MET 4 /* Middle European dst */
+#define DST_EET 5 /* Eastern European dst */
+#define DST_CAN 6 /* Canada */
-#ifndef _TIMEVAL_DEFINED
-#define _TIMEVAL_DEFINED
-struct timeval {
- time_t tv_sec;
- suseconds_t tv_usec;
+#if __BSD_VISIBLE
+struct bintime {
+ time_t sec;
+ uint64_t frac;
-/* BSD time macros used by RTEMS code */
-#if defined (__rtems__) || defined (__CYGWIN__)
-/* Convenience macros for operations on timevals.
- NOTE: `timercmp' does not work for >= or <=. */
-#define timerisset(tvp) ((tvp)->tv_sec || (tvp)->tv_usec)
-#define timerclear(tvp) ((tvp)->tv_sec = (tvp)->tv_usec = 0)
-#define timercmp(a, b, CMP) \
- (((a)->tv_sec == (b)->tv_sec) ? \
- ((a)->tv_usec CMP (b)->tv_usec) : \
- ((a)->tv_sec CMP (b)->tv_sec))
-#define timeradd(a, b, result) \
- do { \
- (result)->tv_sec = (a)->tv_sec + (b)->tv_sec; \
- (result)->tv_usec = (a)->tv_usec + (b)->tv_usec; \
- if ((result)->tv_usec >= 1000000) \
- ++(result)->tv_sec; \
- (result)->tv_usec -= 1000000; \
- } while (0)
-#define timersub(a, b, result) \
- do { \
- (result)->tv_sec = (a)->tv_sec - (b)->tv_sec; \
- (result)->tv_usec = (a)->tv_usec - (b)->tv_usec; \
- if ((result)->tv_usec < 0) { \
- --(result)->tv_sec; \
- (result)->tv_usec += 1000000; \
- } while (0)
-#endif /* defined (__rtems__) || defined (__CYGWIN__) */
-#endif /* !_TIMEVAL_DEFINED */
+static __inline void
+bintime_addx(struct bintime *_bt, uint64_t _x)
+ uint64_t _u;
-struct timezone {
- int tz_minuteswest;
- int tz_dsttime;
+ _u = _bt->frac;
+ _bt->frac += _x;
+ if (_u > _bt->frac)
+ _bt->sec++;
+bintime_add(struct bintime *_bt, const struct bintime *_bt2)
+ uint64_t _u;
+ _u = _bt->frac;
+ _bt->frac += _bt2->frac;
+ _bt->sec++;
+ _bt->sec += _bt2->sec;
+bintime_sub(struct bintime *_bt, const struct bintime *_bt2)
+ uint64_t _u;
+ _u = _bt->frac;
+ _bt->frac -= _bt2->frac;
+ if (_u < _bt->frac)
+ _bt->sec--;
+ _bt->sec -= _bt2->sec;
+bintime_mul(struct bintime *_bt, u_int _x)
+ uint64_t _p1, _p2;
+ _p1 = (_bt->frac & 0xffffffffull) * _x;
+ _p2 = (_bt->frac >> 32) * _x + (_p1 >> 32);
+ _bt->sec *= _x;
+ _bt->sec += (_p2 >> 32);
+ _bt->frac = (_p2 << 32) | (_p1 & 0xffffffffull);
+bintime_shift(struct bintime *_bt, int _exp)
+ if (_exp > 0) {
+ _bt->sec <<= _exp;
+ _bt->sec |= _bt->frac >> (64 - _exp);
+ _bt->frac <<= _exp;
+ } else if (_exp < 0) {
+ _bt->frac >>= -_exp;
+ _bt->frac |= (uint64_t)_bt->sec << (64 + _exp);
+ _bt->sec >>= -_exp;
+#define bintime_clear(a) ((a)->sec = (a)->frac = 0)
+#define bintime_isset(a) ((a)->sec || (a)->frac)
+#define bintime_cmp(a, b, cmp) \
+ (((a)->sec == (b)->sec) ? \
+ ((a)->frac cmp (b)->frac) : \
+ ((a)->sec cmp (b)->sec))
+#define SBT_1S ((sbintime_t)1 << 32)
+#define SBT_1M (SBT_1S * 60)
+#define SBT_1MS (SBT_1S / 1000)
+#define SBT_1US (SBT_1S / 1000000)
+#define SBT_1NS (SBT_1S / 1000000000)
+#define SBT_MAX 0x7fffffffffffffffLL
+static __inline int
+sbintime_getsec(sbintime_t _sbt)
+ return (_sbt >> 32);
+static __inline sbintime_t
+bttosbt(const struct bintime _bt)
+ return (((sbintime_t)_bt.sec << 32) + (_bt.frac >> 32));
+static __inline struct bintime
+sbttobt(sbintime_t _sbt)
+ struct bintime _bt;
+ _bt.sec = _sbt >> 32;
+ _bt.frac = _sbt << 32;
+ return (_bt);
+ * Background information:
+ * When converting between timestamps on parallel timescales of differing
+ * resolutions it is historical and scientific practice to round down rather
+ * than doing 4/5 rounding.
+ * The date changes at midnight, not at noon.
+ * Even at 15:59:59.999999999 it's not four'o'clock.
+ * time_second ticks after N.999999999 not after N.4999999999
+bintime2timespec(const struct bintime *_bt, struct timespec *_ts)
+ _ts->tv_sec = _bt->sec;
+ _ts->tv_nsec = ((uint64_t)1000000000 *
+ (uint32_t)(_bt->frac >> 32)) >> 32;
+timespec2bintime(const struct timespec *_ts, struct bintime *_bt)
+ _bt->sec = _ts->tv_sec;
+ /* 18446744073 = int(2^64 / 1000000000) */
+ _bt->frac = _ts->tv_nsec * (uint64_t)18446744073LL;
+bintime2timeval(const struct bintime *_bt, struct timeval *_tv)
+ _tv->tv_sec = _bt->sec;
+ _tv->tv_usec = ((uint64_t)1000000 * (uint32_t)(_bt->frac >> 32)) >> 32;
+timeval2bintime(const struct timeval *_tv, struct bintime *_bt)
+ _bt->sec = _tv->tv_sec;
+ /* 18446744073709 = int(2^64 / 1000000) */
+ _bt->frac = _tv->tv_usec * (uint64_t)18446744073709LL;
+static __inline struct timespec
+sbttots(sbintime_t _sbt)
+ struct timespec _ts;
+ _ts.tv_sec = _sbt >> 32;
+ _ts.tv_nsec = ((uint64_t)1000000000 * (uint32_t)_sbt) >> 32;
+ return (_ts);
+tstosbt(struct timespec _ts)
+ return (((sbintime_t)_ts.tv_sec << 32) +
+ (_ts.tv_nsec * (((uint64_t)1 << 63) / 500000000) >> 32));
+static __inline struct timeval
+sbttotv(sbintime_t _sbt)
+ struct timeval _tv;
+ _tv.tv_sec = _sbt >> 32;
+ _tv.tv_usec = ((uint64_t)1000000 * (uint32_t)_sbt) >> 32;
+ return (_tv);
+tvtosbt(struct timeval _tv)
+ return (((sbintime_t)_tv.tv_sec << 32) +
+ (_tv.tv_usec * (((uint64_t)1 << 63) / 500000) >> 32));
+#ifdef _KERNEL
+/* Operations on timespecs */
+#define timespecclear(tvp) ((tvp)->tv_sec = (tvp)->tv_nsec = 0)
+#define timespecisset(tvp) ((tvp)->tv_sec || (tvp)->tv_nsec)
+#define timespeccmp(tvp, uvp, cmp) \
+ ((tvp)->tv_nsec cmp (uvp)->tv_nsec) : \
+#define timespecadd(vvp, uvp) \
+ do { \
+ (vvp)->tv_sec += (uvp)->tv_sec; \
+ (vvp)->tv_nsec += (uvp)->tv_nsec; \
+ if ((vvp)->tv_nsec >= 1000000000) { \
+ (vvp)->tv_nsec -= 1000000000; \
+ } while (0)
+#define timespecsub(vvp, uvp) \
+ do { \
+ (vvp)->tv_sec -= (uvp)->tv_sec; \
+ (vvp)->tv_nsec -= (uvp)->tv_nsec; \
+ if ((vvp)->tv_nsec < 0) { \
+ (vvp)->tv_nsec += 1000000000; \
+ } while (0)
+/* Operations on timevals. */
+#define timevalclear(tvp) ((tvp)->tv_sec = (tvp)->tv_usec = 0)
+#define timevalisset(tvp) ((tvp)->tv_sec || (tvp)->tv_usec)
+#define timevalcmp(tvp, uvp, cmp) \
+/* timevaladd and timevalsub are not inlined */
+#endif /* _KERNEL */
#ifdef __CYGWIN__
#include <cygwin/sys_time.h>
#endif /* __CYGWIN__ */
-#define ITIMER_REAL 0
-#define ITIMER_VIRTUAL 1
-#define ITIMER_PROF 2
+ * Names of the interval timers, and structure
+ * defining a timer setting.
+#define ITIMER_REAL 0
+#define ITIMER_VIRTUAL 1
+#define ITIMER_PROF 2
-struct itimerval {
- struct timeval it_interval;
- struct timeval it_value;
+struct itimerval {
+ struct timeval it_interval; /* timer interval */
+ struct timeval it_value; /* current value */
-#ifdef _COMPILING_NEWLIB
-int _EXFUN(_gettimeofday, (struct timeval *__p, void *__tz));
-#endif
+#ifdef _KERNEL
+ * Kernel to clock driver interface.
+void inittodr(time_t base);
+void resettodr(void);
+extern volatile time_t time_second;
+extern volatile time_t time_uptime;
+extern struct bintime boottimebin;
+extern struct timeval boottime;
+extern struct bintime tc_tick_bt;
+extern sbintime_t tc_tick_sbt;
+extern struct bintime tick_bt;
+extern sbintime_t tick_sbt;
+extern int tc_precexp;
+extern int tc_timepercentage;
+extern struct bintime bt_timethreshold;
+extern struct bintime bt_tickthreshold;
+extern sbintime_t sbt_timethreshold;
+extern sbintime_t sbt_tickthreshold;
+ * Functions for looking at our clock: [get]{bin,nano,micro}[up]time()
+ * Functions without the "get" prefix returns the best timestamp
+ * we can produce in the given format.
+ * "bin" == struct bintime == seconds + 64 bit fraction of seconds.
+ * "nano" == struct timespec == seconds + nanoseconds.
+ * "micro" == struct timeval == seconds + microseconds.
+ * Functions containing "up" returns time relative to boot and
+ * should be used for calculating time intervals.
+ * Functions without "up" returns UTC time.
+ * Functions with the "get" prefix returns a less precise result
+ * much faster than the functions without "get" prefix and should
+ * be used where a precision of 1/hz seconds is acceptable or where
+ * performance is priority. (NB: "precision", _not_ "resolution" !)
+void binuptime(struct bintime *bt);
+void nanouptime(struct timespec *tsp);
+void microuptime(struct timeval *tvp);
+sbinuptime(void)
+ binuptime(&_bt);
+ return (bttosbt(_bt));
+void bintime(struct bintime *bt);
+void nanotime(struct timespec *tsp);
+void microtime(struct timeval *tvp);
+void getbinuptime(struct bintime *bt);
+void getnanouptime(struct timespec *tsp);
+void getmicrouptime(struct timeval *tvp);
+getsbinuptime(void)
+ getbinuptime(&_bt);
+void getbintime(struct bintime *bt);
+void getnanotime(struct timespec *tsp);
+void getmicrotime(struct timeval *tvp);
+/* Other functions */
+int itimerdecr(struct itimerval *itp, int usec);
+int itimerfix(struct timeval *tv);
+int ppsratecheck(struct timeval *, int *, int);
+int ratecheck(struct timeval *, const struct timeval *);
+void timevaladd(struct timeval *t1, const struct timeval *t2);
+void timevalsub(struct timeval *t1, const struct timeval *t2);
+int tvtohz(struct timeval *tv);
+#define TC_DEFAULTPERC 5
+#define BT2FREQ(bt) \
+ (((uint64_t)0x8000000000000000 + ((bt)->frac >> 2)) / \
+ ((bt)->frac >> 1))
+#define SBT2FREQ(sbt) ((SBT_1S + ((sbt) >> 1)) / (sbt))
+#define FREQ2BT(freq, bt) \
+ (bt)->sec = 0; \
+ (bt)->frac = ((uint64_t)0x8000000000000000 / (freq)) << 1; \
+#define TIMESEL(sbt, sbt2) \
+ (((sbt2) >= sbt_timethreshold) ? \
+ ((*(sbt) = getsbinuptime()), 1) : ((*(sbt) = sbinuptime()), 0))
+#else /* !_KERNEL */
+#include <time.h>
+#include <sys/cdefs.h>
+__BEGIN_DECLS
+int _EXFUN(setitimer, (int __which, const struct itimerval *__restrict __value,
+ struct itimerval *__restrict __ovalue));
+int _EXFUN(utimes, (const char *__path, const struct timeval *__tvp));
-int _EXFUN(gettimeofday, (struct timeval *__restrict __p,
- void *__restrict __tz));
#if __BSD_VISIBLE
-int _EXFUN(settimeofday, (const struct timeval *, const struct timezone *));
int _EXFUN(adjtime, (const struct timeval *, struct timeval *));
+int _EXFUN(futimes, (int, const struct timeval *));
+int _EXFUN(futimesat, (int, const char *, const struct timeval [2]));
+int _EXFUN(lutimes, (const char *, const struct timeval *));
+int _EXFUN(settimeofday, (const struct timeval *, const struct timezone *));
#endif
-int _EXFUN(utimes, (const char *__path, const struct timeval *__tvp));
+#if __XSI_VISIBLE
int _EXFUN(getitimer, (int __which, struct itimerval *__value));
-int _EXFUN(setitimer, (int __which, const struct itimerval *__restrict __value,
- struct itimerval *__restrict __ovalue));
+int _EXFUN(gettimeofday, (struct timeval *__restrict __p,
+ void *__restrict __tz));
+#endif
-#ifdef __cplusplus
+#ifdef _COMPILING_NEWLIB
+int _EXFUN(_gettimeofday, (struct timeval *__p, void *__tz));
#endif
-#endif /* _SYS_TIME_H_ */
+__END_DECLS
+#endif /* !_KERNEL */
+#endif /* !_SYS_TIME_H_ */
diff --git a/newlib/libc/include/sys/types.h b/newlib/libc/include/sys/types.h
index f20ef11..227f83c 100644
--- a/newlib/libc/include/sys/types.h
+++ b/newlib/libc/include/sys/types.h
@@ -267,7 +267,13 @@ typedef _TIMER_T_ timer_t;
#endif
typedef unsigned long useconds_t;
-typedef long suseconds_t;
+#endif
+typedef __int64_t sbintime_t;
#include <sys/features.h>
1.8.4.5
