[PATCH] libgomp: Add RTEMS support
Sebastian Huber
Fri Mar 13 10:38:12 UTC 2015
I would like to commit this patch to GCC 4.9 and 5.0.
libgomp/ChangeLog
2015-03-13 Sebastian Huber <sebastian.huber at embedded-brains.de>
* configure.tgt (*-*-rtems*): Use local-exec TLS model.
* configure.ac (*-*-rtems*): Assume Pthread is supported.
(pthread.h): Check for this header file.
* configure: Regenerate.
libgomp/configure | 22 ++++++++++++++--------
libgomp/configure.ac | 42 ++++++++++++++++++++++++------------------
libgomp/configure.tgt | 4 ++++
3 files changed, 42 insertions(+), 26 deletions(-)
diff --git a/libgomp/configure b/libgomp/configure
index 0818707..e39787c 100755
--- a/libgomp/configure
+++ b/libgomp/configure
@@ -14611,7 +14611,7 @@ $as_echo "#define STRING_WITH_STRINGS 1" >>confdefs.h
fi
-for ac_header in unistd.h semaphore.h sys/loadavg.h sys/time.h sys/time.h
+for ac_header in pthread.h unistd.h semaphore.h sys/loadavg.h sys/time.h sys/time.h
do :
as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
ac_fn_c_check_header_mongrel "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default"
@@ -15033,14 +15033,19 @@ ac_config_commands="$ac_config_commands gstdint.h"
-# Check to see if -pthread or -lpthread is needed. Prefer the former.
-# In case the pthread.h system header is not found, this test will fail.
XPCFLAGS=""
-CFLAGS="$CFLAGS -pthread"
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+case "$host" in
+ *-*-rtems*)
+ # RTEMS supports Pthreads, but the library is not available at GCC build time.
+ # Check to see if -pthread or -lpthread is needed. Prefer the former.
+ # In case the pthread.h system header is not found, this test will fail.
+ CFLAGS="$CFLAGS -pthread"
+ cat confdefs.h - <<_ACEOF >conftest.$ac_ext
/* end confdefs.h. */
#include <pthread.h>
- void *g(void *d) { return NULL; }
+ void *g(void *d) { return NULL; }
int
main ()
@@ -15053,10 +15058,10 @@ if ac_fn_c_try_link "$LINENO"; then :
XPCFLAGS=" -Wc,-pthread"
else
CFLAGS="$save_CFLAGS" LIBS="-lpthread $LIBS"
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
int
main ()
@@ -15075,6 +15080,7 @@ rm -f core conftest.err conftest.$ac_objext \
fi
conftest$ac_exeext conftest.$ac_ext
+esac
# Plugins for offload execution, configure.ac fragment. -*- mode: autoconf -*-
diff --git a/libgomp/configure.ac b/libgomp/configure.ac
index 4687b01..51e646d 100644
--- a/libgomp/configure.ac
+++ b/libgomp/configure.ac
@@ -170,28 +170,34 @@ AC_SUBST(libtool_VERSION)
AC_STDC_HEADERS
AC_HEADER_TIME
ACX_HEADER_STRING
-AC_CHECK_HEADERS(unistd.h semaphore.h sys/loadavg.h sys/time.h sys/time.h)
+AC_CHECK_HEADERS(pthread.h unistd.h semaphore.h sys/loadavg.h sys/time.h sys/time.h)
GCC_HEADER_STDINT(gstdint.h)
XPCFLAGS=""
-AC_LINK_IFELSE(
- [AC_LANG_PROGRAM(
- [#include <pthread.h>
- void *g(void *d) { return NULL; }],
- [pthread_t t; pthread_create(&t,NULL,g,NULL);])],
- [XPCFLAGS=" -Wc,-pthread"],
- [CFLAGS="$save_CFLAGS" LIBS="-lpthread $LIBS"
- AC_LINK_IFELSE(
- [AC_LANG_PROGRAM(
- [AC_MSG_ERROR([Pthreads are required to build libgomp])])])
+case "$host" in
+ *-*-rtems*)
+ AC_LINK_IFELSE(
+ [AC_LANG_PROGRAM(
+ [#include <pthread.h>
+ void *g(void *d) { return NULL; }],
+ [pthread_t t; pthread_create(&t,NULL,g,NULL);])],
+ [XPCFLAGS=" -Wc,-pthread"],
+ [CFLAGS="$save_CFLAGS" LIBS="-lpthread $LIBS"
+ AC_LINK_IFELSE(
+ [AC_LANG_PROGRAM(
+ [AC_MSG_ERROR([Pthreads are required to build libgomp])])])
+esac
m4_include([plugin/configfrag.ac])
diff --git a/libgomp/configure.tgt b/libgomp/configure.tgt
index ad98de1..2970f6f 100644
--- a/libgomp/configure.tgt
+++ b/libgomp/configure.tgt
@@ -20,6 +20,10 @@ if test $gcc_cv_have_tls = yes ; then
*-*-linux* | *-*-gnu*)
XCFLAGS="${XCFLAGS} -ftls-model=initial-exec"
+ *-*-rtems*)
+ XCFLAGS="${XCFLAGS} -ftls-model=local-exec"
esac
fi
1.8.4.5
