RPi Support GSoC 2015
Gedare Bloom gedare at gwu.edu
Fri Mar 13 16:21:13 UTC 2015
Hi,
RPi is a good open project. The BSP is in c/src/lib/libbsp/arm/raspberrypi
I think the prior gsoc effort has some links/pointers in it. You will
need to have the board and prove you can build RTEMS for it and run
it.
Gedare
On Fri, Mar 13, 2015 at 11:43 AM, Юрий Шевцов <ungetch at gmail.com> wrote:
> Hello there! I would like to participate in GSoC with RTEMS Project. As for
> now I'm considering to improve RPi support. Project's page says that some
> progress has done. Where can I found this code and some examples for other
> boards maybe. I have lurked RTEMS git repo a little but haven't found any
> RPi related stuff. Thanks in advance)
> devel mailing list
> devel at rtems.org
