[PATCH] preliminary Raspberry Pi Model 2 support
Alan Cudmore
alan.cudmore at gmail.com
Sun Mar 15 16:04:06 UTC 2015
c/src/lib/libbsp/arm/raspberrypi/configure.ac | 8 +++++++
.../libbsp/arm/raspberrypi/include/raspberrypi.h | 26 +++++++++++++++++-----
.../arm/raspberrypi/make/custom/raspberrypi.cfg | 15 +------------
.../arm/raspberrypi/make/custom/raspberrypi.inc | 18 +++++++++++++++
.../arm/raspberrypi/make/custom/raspberrypi2.cfg | 7 ++++++
.../arm/raspberrypi/startup/mm_config_table.c | 5 +++--
6 files changed, 57 insertions(+), 22 deletions(-)
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg
diff --git a/c/src/lib/libbsp/arm/raspberrypi/configure.ac b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
index 42be4e9..27abe6c 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
+++ b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
@@ -24,6 +24,14 @@ AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP start])
+# Is this a Raspberry Pi 2?
+RTEMS_BSPOPTS_SET([BSP_IS_RPI2],[raspberrypi2],[1])
+RTEMS_BSPOPTS_SET([BSP_IS_RPI2],[*],[0])
+RTEMS_BSPOPTS_HELP([BSP_IS_RPI2],[Set if the BSP variant is Raspberry Pi 2.])
+AM_CONDITIONAL(RTEMS_RPI2,[test "$BSP_IS_RPI2" = "1"])
RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
RTEMS_BSP_LINKCMDS
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
index 4cc7eec..e3c4d76 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
@@ -45,6 +45,20 @@
+ * @name Peripheral Base Register Address
+#if (BSP_IS_RPI2 == 1)
+ #define RPI_PERIPHERAL_BASE 0x3F000000
+#else
+ #define RPI_PERIPHERAL_BASE 0x20000000
+#endif
+#define RPI_PERIPHERAL_SIZE 0x01000000
* @name Internal ARM Timer Registers
@@ -52,7 +66,7 @@
#define BCM2835_CLOCK_FREQ 250000000
-#define BCM2835_TIMER_BASE (0x2000B400)
+#define BCM2835_TIMER_BASE (RPI_PERIPHERAL_BASE + 0xB400)
#define BCM2835_TIMER_LOD (BCM2835_TIMER_BASE+0x00)
#define BCM2835_TIMER_VAL (BCM2835_TIMER_BASE+0x04)
@@ -74,7 +88,7 @@
-#define BCM2835_GPIO_REGS_BASE (0x20200000)
+#define BCM2835_GPIO_REGS_BASE (RPI_PERIPHERAL_BASE + 0x200000)
#define BCM2835_GPIO_GPFSEL1 (BCM2835_GPIO_REGS_BASE+0x04)
#define BCM2835_GPIO_GPSET0 (BCM2835_GPIO_REGS_BASE+0x1C)
@@ -90,7 +104,7 @@
-#define BCM2835_AUX_BASE (0x20215000)
+#define BCM2835_AUX_BASE (RPI_PERIPHERAL_BASE + 0x215000)
#define AUX_ENABLES (BCM2835_AUX_BASE+0x04)
#define AUX_MU_IO_REG (BCM2835_AUX_BASE+0x40)
@@ -115,7 +129,7 @@
-#define BCM2835_UART0_BASE (0x20201000)
+#define BCM2835_UART0_BASE (RPI_PERIPHERAL_BASE + 0x201000)
#define BCM2835_UART0_DR (BCM2835_UART0_BASE+0x00)
#define BCM2835_UART0_RSRECR (BCM2835_UART0_BASE+0x04)
@@ -155,7 +169,7 @@
-#define BCM2835_BASE_INTC (0x2000B200)
+#define BCM2835_BASE_INTC (RPI_PERIPHERAL_BASE + 0xB200)
#define BCM2835_IRQ_BASIC (BCM2835_BASE_INTC + 0x00)
#define BCM2835_IRQ_PENDING1 (BCM2835_BASE_INTC + 0x04)
@@ -182,7 +196,7 @@
* it's own RTOS. 1 and 3 are available for use in
* RTEMS.
-#define BCM2835_GPU_TIMER_BASE (0x20003000)
+#define BCM2835_GPU_TIMER_BASE (RPI_PERIPHERAL_BASE + 0x3000)
#define BCM2835_GPU_TIMER_CS (BCM2835_TIMER_BASE+0x00)
#define BCM2835_GPU_TIMER_CLO (BCM2835_TIMER_BASE+0x04)
diff --git a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
index 48ac0f8..759b79d 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
+++ b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
@@ -1,20 +1,7 @@
# Config file for RASPBERRYPI
-include $(RTEMS_ROOT)/make/custom/default.cfg
-RTEMS_CPU = arm
+include $(RTEMS_ROOT)/make/custom/raspberrypi.inc
CPU_CFLAGS = -mcpu=arm1176jzf-s
-CFLAGS_OPTIMIZE_V = -O2 -g
-# This defines the operations performed on the linked executable.
-# is currently required.
-define bsp-post-link
- $(OBJCOPY) -O binary --strip-all \
- $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
- $(SIZE) $(basename $@)$(EXEEXT)
-endef
diff --git a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc
new file mode 100644
index 0000000..8a756cd
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc
@@ -0,0 +1,18 @@
+# Config file for Raspberry Pi variants.
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = arm
+CFLAGS_OPTIMIZE_V ?= -O2 -g
+# This defines the operations performed on the linked executable.
+# is currently required.
+define bsp-post-link
+ $(OBJCOPY) -O binary --strip-all \
+ $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
+ $(SIZE) $(basename $@)$(EXEEXT)
+endef
diff --git a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg
index 0000000..f480c68
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg
@@ -0,0 +1,7 @@
+# Config file for RASPBERRYPI 2
+CPU_CFLAGS = -march=armv7-a -mtune=cortex-a7
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
index 398ba98..36c6eed 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
@@ -20,6 +20,7 @@
* http://www.rtems.org/license/LICENSE.
+#include <bsp.h>
#include <bsp/arm-cp15-start.h>
const arm_cp15_start_section_config arm_cp15_start_mmu_config_table[] = {
@@ -64,8 +65,8 @@ const arm_cp15_start_section_config arm_cp15_start_mmu_config_table[] = {
.end = (uint32_t) bsp_section_stack_end,
.flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
- .begin = 0x20000000,
- .end = 0x21000000,
+ .begin = RPI_PERIPHERAL_BASE,
+ .end = RPI_PERIPHERAL_BASE + RPI_PERIPHERAL_SIZE,
.flags = ARMV7_MMU_DEVICE
1.9.1
