[PATCH] preliminary Raspberry Pi Model 2 support
Alan Cudmore
alan.cudmore at gmail.com
Sun Mar 15 16:09:58 UTC 2015
This patch adds a BSP variant for the Raspberry Pi 2.
--enable-rtemsbsp="raspberrypi2 raspberrypi"
For the current BSP, the only change was the peripheral register base
address and the compiler options.
The raspberrypi/make/custom rules were re-factored:
raspberrypi.inc -- Common rules
raspberrypi.cfg - Raspberry Pi 1 specific rule/optons
raspberrypi2.cfg -- Raspberry Pi 2 specific rule/options
I tested hello, ticker, unlimited, and paranoia on both the Pi ( Model A+ )
and Pi 2.
Alan
On Sun, Mar 15, 2015 at 12:04 PM, Alan Cudmore <alan.cudmore at gmail.com>
wrote:
> c/src/lib/libbsp/arm/raspberrypi/configure.ac | 8 +++++++
> .../libbsp/arm/raspberrypi/include/raspberrypi.h | 26
> .../arm/raspberrypi/make/custom/raspberrypi.cfg | 15 +------------
> .../arm/raspberrypi/make/custom/raspberrypi.inc | 18 +++++++++++++++
> .../arm/raspberrypi/make/custom/raspberrypi2.cfg | 7 ++++++
> .../arm/raspberrypi/startup/mm_config_table.c | 5 +++--
> 6 files changed, 57 insertions(+), 22 deletions(-)
> create mode 100644
> c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc
> create mode 100644
> c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
> b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
> index 42be4e9..27abe6c 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/configure.ac
> +++ b/c/src/lib/libbsp/arm/raspberrypi/configure.ac
> @@ -24,6 +24,14 @@ AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" =
> "yes")
> RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
> RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP
> start])
> +# Is this a Raspberry Pi 2?
> +RTEMS_BSPOPTS_SET([BSP_IS_RPI2],[raspberrypi2],[1])
> +RTEMS_BSPOPTS_SET([BSP_IS_RPI2],[*],[0])
> +RTEMS_BSPOPTS_HELP([BSP_IS_RPI2],[Set if the BSP variant is Raspberry Pi
> 2.])
> +AM_CONDITIONAL(RTEMS_RPI2,[test "$BSP_IS_RPI2" = "1"])
> RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
> RTEMS_BSP_LINKCMDS
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
> b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
> index 4cc7eec..e3c4d76 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
> +++ b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
> @@ -45,6 +45,20 @@
> + * @name Peripheral Base Register Address
> +#if (BSP_IS_RPI2 == 1)
> + #define RPI_PERIPHERAL_BASE 0x3F000000
> +#else
> + #define RPI_PERIPHERAL_BASE 0x20000000
> +#endif
> +#define RPI_PERIPHERAL_SIZE 0x01000000
> * @name Internal ARM Timer Registers
> @@ -52,7 +66,7 @@
> #define BCM2835_CLOCK_FREQ 250000000
> -#define BCM2835_TIMER_BASE (0x2000B400)
> +#define BCM2835_TIMER_BASE (RPI_PERIPHERAL_BASE + 0xB400)
> #define BCM2835_TIMER_LOD (BCM2835_TIMER_BASE+0x00)
> #define BCM2835_TIMER_VAL (BCM2835_TIMER_BASE+0x04)
> @@ -74,7 +88,7 @@
> -#define BCM2835_GPIO_REGS_BASE (0x20200000)
> +#define BCM2835_GPIO_REGS_BASE (RPI_PERIPHERAL_BASE + 0x200000)
> #define BCM2835_GPIO_GPFSEL1 (BCM2835_GPIO_REGS_BASE+0x04)
> #define BCM2835_GPIO_GPSET0 (BCM2835_GPIO_REGS_BASE+0x1C)
> @@ -90,7 +104,7 @@
> -#define BCM2835_AUX_BASE (0x20215000)
> +#define BCM2835_AUX_BASE (RPI_PERIPHERAL_BASE + 0x215000)
> #define AUX_ENABLES (BCM2835_AUX_BASE+0x04)
> #define AUX_MU_IO_REG (BCM2835_AUX_BASE+0x40)
> @@ -115,7 +129,7 @@
> -#define BCM2835_UART0_BASE (0x20201000)
> +#define BCM2835_UART0_BASE (RPI_PERIPHERAL_BASE + 0x201000)
> #define BCM2835_UART0_DR (BCM2835_UART0_BASE+0x00)
> #define BCM2835_UART0_RSRECR (BCM2835_UART0_BASE+0x04)
> @@ -155,7 +169,7 @@
> -#define BCM2835_BASE_INTC (0x2000B200)
> +#define BCM2835_BASE_INTC (RPI_PERIPHERAL_BASE + 0xB200)
> #define BCM2835_IRQ_BASIC (BCM2835_BASE_INTC + 0x00)
> #define BCM2835_IRQ_PENDING1 (BCM2835_BASE_INTC + 0x04)
> @@ -182,7 +196,7 @@
> * it's own RTOS. 1 and 3 are available for use in
> * RTEMS.
> -#define BCM2835_GPU_TIMER_BASE (0x20003000)
> +#define BCM2835_GPU_TIMER_BASE (RPI_PERIPHERAL_BASE + 0x3000)
> #define BCM2835_GPU_TIMER_CS (BCM2835_TIMER_BASE+0x00)
> #define BCM2835_GPU_TIMER_CLO (BCM2835_TIMER_BASE+0x04)
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
> b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
> index 48ac0f8..759b79d 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
> +++ b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
> @@ -1,20 +1,7 @@
> # Config file for RASPBERRYPI
> -include $(RTEMS_ROOT)/make/custom/default.cfg
> -RTEMS_CPU = arm
> +include $(RTEMS_ROOT)/make/custom/raspberrypi.inc
> CPU_CFLAGS = -mcpu=arm1176jzf-s
> -CFLAGS_OPTIMIZE_V = -O2 -g
> -# This defines the operations performed on the linked executable.
> -# is currently required.
> -define bsp-post-link
> - $(OBJCOPY) -O binary --strip-all \
> - $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
> - $(SIZE) $(basename $@)$(EXEEXT)
> -endef
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc
> b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc
> new file mode 100644
> index 0000000..8a756cd
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc
> @@ -0,0 +1,18 @@
> +# Config file for Raspberry Pi variants.
> +include $(RTEMS_ROOT)/make/custom/default.cfg
> +RTEMS_CPU = arm
> +CFLAGS_OPTIMIZE_V ?= -O2 -g
> +# This defines the operations performed on the linked executable.
> +# is currently required.
> +define bsp-post-link
> + $(OBJCOPY) -O binary --strip-all \
> + $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
> + $(SIZE) $(basename $@)$(EXEEXT)
> +endef
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg
> b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg
> index 0000000..f480c68
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi2.cfg
> @@ -0,0 +1,7 @@
> +# Config file for RASPBERRYPI 2
> +CPU_CFLAGS = -march=armv7-a -mtune=cortex-a7
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> index 398ba98..36c6eed 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
> @@ -20,6 +20,7 @@
> * http://www.rtems.org/license/LICENSE.
> +#include <bsp.h>
> #include <bsp/arm-cp15-start.h>
> const arm_cp15_start_section_config arm_cp15_start_mmu_config_table[] = {
> @@ -64,8 +65,8 @@ const arm_cp15_start_section_config
> .end = (uint32_t) bsp_section_stack_end,
> .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
> - .begin = 0x20000000,
> - .end = 0x21000000,
> + .begin = RPI_PERIPHERAL_BASE,
> + .end = RPI_PERIPHERAL_BASE + RPI_PERIPHERAL_SIZE,
> .flags = ARMV7_MMU_DEVICE
> 1.9.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150315/232ff4e3/attachment-0002.html>
