rtems-source-builder on cygwin/64
Chris Johns
chrisj at rtems.org
Sun Mar 15 21:19:48 UTC 2015
[ back on list ]
On 14/03/2015 9:51 pm, emanuel stiebler wrote:
> On 2015-03-14 11:26, Chris Johns wrote:
>> On 14/03/2015 9:03 pm, emanuel stiebler wrote:
>>> But, anyway, it still "thinks" it is on MinGW?
>> Hmm yeah which is not right. Can you send me the rsb-report file plus
>> the output of 'python windows.py'.
> Sure !
Thanks. Can you please try the attached windows.py ?
> $ python windows.py
> {'___setup_shell': ('exe', 'required', '%{__sh}'),
> '__bash': ('exe', 'required', 'bash'),
> '__bison': ('exe', 'required', 'bison'),
> '__bzip2': ('exe', 'required', 'bzip2'),
> '__cat': ('exe', 'required', 'cat'),
> '__cc': ('exe', 'required', 'gcc'),
> '__chgrp': ('exe', 'required', 'chgrp'),
> '__chmod': ('exe', 'required', 'chmod'),
> '__chown': ('exe', 'required', 'chown'),
> '__cp': ('exe', 'required', 'cp'),
> '__cvs': ('exe', 'required', 'cvs'),
> '__cxx': ('exe', 'required', 'g++'),
> '__flex': ('exe', 'required', 'flex'),
> '__git': ('exe', 'required', 'git'),
> '__grep': ('exe', 'required', 'grep'),
> '__gzip': ('exe', 'required', 'gzip'),
> '__id': ('exe', 'required', 'id'),
> '__install': ('exe', 'required', 'install'),
> '__install_info': ('exe', 'required', 'install-info'),
> '__ld': ('exe', 'required', 'ld'),
> '__ldconfig': ('exe', 'none', ''),
> '__makeinfo': ('exe', 'required', 'makeinfo'),
> '__mkdir': ('exe', 'required', 'mkdir'),
> '__mv': ('exe', 'required', 'mv'),
> '__nm': ('exe', 'required', 'nm'),
> '__objcopy': ('exe', 'required', 'objcopy'),
> '__objdump': ('exe', 'required', 'objdump'),
> '__patch': ('exe', 'required', 'patch'),
> '__patch_bin': ('exe', 'required', 'patch'),
> '__rm': ('exe', 'required', 'rm'),
> '__sed': ('exe', 'required', 'sed'),
> '__sh': ('exe', 'required', 'sh'),
> '__tar': ('exe', 'required', 'bsdtar'),
> '__touch': ('exe', 'required', 'touch'),
> '__unzip': ('exe', 'required', 'unzip'),
> '__xz': ('exe', 'required', 'xz'),
> '_build': ('triplet', 'required', 'x86_64-w64-mingw32'),
> '_build_alias': ('none', 'none', '%{nil}'),
> '_build_arch': ('none', 'none', 'x86_64'),
> '_build_cpu': ('none', 'none', 'x86_64'),
> '_build_os': ('none', 'none', 'win32'),
> '_build_os_version': ('none', 'none', 'G'),
> '_build_vendor': ('none', 'none', 'microsoft'),
> '_buildshell': ('exe', 'required', '%{__sh}'),
> '_host': ('triplet', 'required', 'x86_64-w64-mingw32'),
> '_host_alias': ('none', 'none', '%{nil}'),
> '_host_arch': ('none', 'none', 'x86_64'),
> '_host_cpu': ('none', 'none', 'x86_64'),
> '_host_os': ('none', 'none', 'win32'),
> '_host_vendor': ('none', 'none', 'microsoft'),
> '_ncpus': ('none', 'none', '8'),
> '_os': ('none', 'none', 'win32'),
> '_usr': ('dir', 'optional', '/opt/local'),
> '_var': ('dir', 'optional', '/opt/local/var')}
> emu at w530 ~/RTEMS.Work/rtems-source-builder/source-builder/sb
Type: text/x-python
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150316/fa20833e/attachment-0001.py>
