[PATCH] score: Delete unused _Timestamp_Is_valid()
Alexander Krutwig
alexander.krutwig at embedded-brains.de
Thu Mar 19 12:52:22 UTC 2015
cpukit/score/include/rtems/score/timestamp.h | 18 ------------------
cpukit/score/include/rtems/score/timestamp64.h | 13 -------------
2 files changed, 31 deletions(-)
diff --git a/cpukit/score/include/rtems/score/timestamp.h b/cpukit/score/include/rtems/score/timestamp.h
index 895afcc..5c23979 100644
--- a/cpukit/score/include/rtems/score/timestamp.h
+++ b/cpukit/score/include/rtems/score/timestamp.h
@@ -109,24 +109,6 @@ extern "C" {
#endif
- * @brief Determines the validity of a timestamp.
- * This method determines the validity of a timestamp.
- * @param[in] _time points to the timestamp instance to validate.
- * @retval This method returns true if @a time is valid and
- * false otherwise.
-#if CPU_TIMESTAMP_USE_STRUCT_TIMESPEC == TRUE
- #define _Timestamp_Is_valid( _time ) \
- _Timespec_Is_valid( _time )
-#else
- _Timestamp64_Is_valid( _time )
-#endif
* @brief Less than operator for timestamps.
* This method is the less than operator for timestamps.
diff --git a/cpukit/score/include/rtems/score/timestamp64.h b/cpukit/score/include/rtems/score/timestamp64.h
index 55b7d07..3d40ca2 100644
--- a/cpukit/score/include/rtems/score/timestamp64.h
+++ b/cpukit/score/include/rtems/score/timestamp64.h
@@ -106,19 +106,6 @@ static inline void _Timestamp64_implementation_Set_to_zero(
#endif
- * @brief Determines the validity of a 64-bit timestamp.
-#define _Timestamp64_Is_valid( _time ) \
- (1)
static inline bool _Timestamp64_implementation_Less_than(
const Timestamp64_Control *_lhs,
const Timestamp64_Control *_rhs
1.8.4.5
