GSOC 2015 Monkey HTTP Server
Eduardo Silva
eduardo at monkey.io
Thu Mar 19 12:58:52 UTC 2015
Hi Joel,
sorry for the late reply, really busy days :)
As you may know we were not selected this time. So how can we help on this
project ?
best
On Wed, Mar 11, 2015 at 3:12 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> cc'ing Eduardo Silva from the Monkey project. Eduardo,
> you may have to subscribe to get messages back to the
> RTEMS list.
> On 3/11/2015 3:45 PM, Sujay Raj wrote:
> > Hi,
> > I am interested in working on porting the Monkey HTTP Server to RTEMS
> > as a GSOC project.
> > This is the first time I am applying to GSOC and though I have written
> > a lot of code, it is also my first attempt at working in an Open
> > Source project.
> > Some personal projects that I have worked on include developing a
> > hobby operating system ( following Bran's Kernel Development Tutorial
> > and osdev ), writing ray tracers, as well as porting the nweb web
> > server ( 200 lines of C code ) to python ( it was undertaken as an
> > exercise to learn more about the functioning and implementation of
> > webservers ). Further I have familiarity with x86 assembly (nasm), not
> > extraordinary, but fluent.
> > I have successfully compiled and executed sample programs for
> > sparc-sis but from what I have read sparc-sis doesn't support TCP/IP.
> > So I followed the wiki and compiled it for pc386 on QEMU too as it had
> > networking support.
> You either want to use pc386 on qemu or arm/zynq on qemu.
> > I was wondering if this may be the required architecture and simulator
> > for this project.
> > Further, I would like to mention, that though this may be an approach
> > with GSOC in mind, but I wish to end up as a full time contributor for
> > the RTEMS project in time to come as it suits my taste and past
> > experience.
> > Kindly point out things I need to do to proceed and other comments.
> Eduardo mentioned that this may not be enough to occupy your entire
> summer. So we would need to identify other work to bundle with this.
> Monkey for RTEMS should get built as a package inside the RSB. This
> is like the BSD ports where it always builds from source. Fetch upstream,
> patch as needed and build for the embedded architecture.
> Random idea which would need other mentors to buy into. We have an
> old IPV4 stack in the current tree. We have a newer IPV4/V6 IP stack
> outside the tree. And there is a working LWIP port. My concept long
> term has been to divide things into packages:
> + RTEMS (ok done)
> + network stack of choice - done for new IPV4/IPV6 stack. current
> stack is in tree, would need to be pulled out into its own build
> module, LWIP is a candidate for RSB packaging but could get done
> by another student as part of BeagleBone work.
> + network tests - some in the tree, some in network-demos
> + network servers - ftpd, web servers, telnetd, pppd, etc should be
> packages that can be built against your network stack of choice
> This idea hasn't been reviewed by anyone so would need feedback
> but conceptually, it makes network services an add-on to the RTEMS
> core and makes it easier for users to pick a stack. More modular
> pieces.
> The first step though is getting Monkey ported as a package. The
> other steps would need discussing.
> > Regards
> > devel mailing list
> > devel at rtems.org
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
Eduardo Silva
Monkey Software
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150319/0e2307a8/attachment.html>
