GSOC 2015 Monkey HTTP Server
Thu Mar 19 13:18:56 UTC 2015
On March 19, 2015 7:58:52 AM CDT, Eduardo Silva <eduardo at monkey.io> wrote:
>Hi Joel,
>sorry for the late reply, really busy days :)
>As you may know we were not selected this time.
Did Monkey apply separately from Software Freedom Conservancy? I thought the big umbrellas applied to cover the collection of smaller projects.
> So how can we help on
>this project ?
That's up to the student. Sujay?
>best
>On Wed, Mar 11, 2015 at 3:12 PM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>cc'ing Eduardo Silva from the Monkey project. Eduardo,
>you may have to subscribe to get messages back to the
>RTEMS list.
>On 3/11/2015 3:45 PM, Sujay Raj wrote:
>> Hi,
>> I am interested in working on porting the Monkey HTTP Server to RTEMS
>> as a GSOC project.
>> This is the first time I am applying to GSOC and though I have
>written
>> a lot of code, it is also my first attempt at working in an Open
>> Source project.
>> Some personal projects that I have worked on include developing a
>> hobby operating system ( following Bran's Kernel Development Tutorial
>> and osdev ), writing ray tracers, as well as porting the nweb web
>> server ( 200 lines of C code ) to python ( it was undertaken as an
>> exercise to learn more about the functioning and implementation of
>> webservers ). Further I have familiarity with x86 assembly (nasm),
>not
>> extraordinary, but fluent.
>> I have successfully compiled and executed sample programs for
>> sparc-sis but from what I have read sparc-sis doesn't support TCP/IP.
>> So I followed the wiki and compiled it for pc386 on QEMU too as it
>had
>> networking support.
>You either want to use pc386 on qemu or arm/zynq on qemu.
>> I was wondering if this may be the required architecture and
>simulator
>> for this project.
>> Further, I would like to mention, that though this may be an approach
>> with GSOC in mind, but I wish to end up as a full time contributor
>for
>> the RTEMS project in time to come as it suits my taste and past
>> experience.
>> Kindly point out things I need to do to proceed and other comments.
>Eduardo mentioned that this may not be enough to occupy your entire
>summer. So we would need to identify other work to bundle with this.
>Monkey for RTEMS should get built as a package inside the RSB. This
>is like the BSD ports where it always builds from source. Fetch
>upstream,
>patch as needed and build for the embedded architecture.
>Random idea which would need other mentors to buy into. We have an
>old IPV4 stack in the current tree. We have a newer IPV4/V6 IP stack
>outside the tree. And there is a working LWIP port. My concept long
>term has been to divide things into packages:
>+ RTEMS (ok done)
>+ network stack of choice - done for new IPV4/IPV6 stack. current
>   stack is in tree, would need to be pulled out into its own build
>   module, LWIP is a candidate for RSB packaging but could get done
>  by another student as part of BeagleBone work.
>+ network tests - some in the tree, some in network-demos
>+ network servers - ftpd, web servers, telnetd, pppd, etc should be
>   packages that can be built against your network stack of choice
>This idea hasn't been reviewed by anyone so would need feedback
>but conceptually, it makes network services an add-on to the RTEMS
>core and makes it easier for users to pick a stack. More modular
>pieces.
>The first step though is getting Monkey ported as a package. The
>other steps would need discussing.
>> Regards
>> devel mailing list
>> devel at rtems.org
>Joel Sherrill, Ph.D.             Director of Research & Development
>joel.sherrill at OARcorp.com        On-Line Applications Research
>Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>Support Available                (256) 722-9985
>Eduardo Silva
>Monkey Software
--joel
