GSOC 2015 Monkey HTTP Server
Gedare Bloom gedare at gwu.edu
Thu Mar 19 14:51:18 UTC 2015
Eduardo,
You may like to sign-up as a mentor for RTEMS Project in case the
student decides to submit an application to port the Monkey server.
Gedare
On Thu, Mar 19, 2015 at 8:58 AM, Eduardo Silva <eduardo at monkey.io> wrote:
> Hi Joel,
> sorry for the late reply, really busy days :)
> As you may know we were not selected this time. So how can we help on this
> project ?
> best
> On Wed, Mar 11, 2015 at 3:12 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
>> cc'ing Eduardo Silva from the Monkey project. Eduardo,
>> you may have to subscribe to get messages back to the
>> RTEMS list.
>> On 3/11/2015 3:45 PM, Sujay Raj wrote:
>> > Hi,
>> > I am interested in working on porting the Monkey HTTP Server to RTEMS
>> > as a GSOC project.
>> > This is the first time I am applying to GSOC and though I have written
>> > a lot of code, it is also my first attempt at working in an Open
>> > Source project.
>> > Some personal projects that I have worked on include developing a
>> > hobby operating system ( following Bran's Kernel Development Tutorial
>> > and osdev ), writing ray tracers, as well as porting the nweb web
>> > server ( 200 lines of C code ) to python ( it was undertaken as an
>> > exercise to learn more about the functioning and implementation of
>> > webservers ). Further I have familiarity with x86 assembly (nasm), not
>> > extraordinary, but fluent.
>> > I have successfully compiled and executed sample programs for
>> > sparc-sis but from what I have read sparc-sis doesn't support TCP/IP.
>> > So I followed the wiki and compiled it for pc386 on QEMU too as it had
>> > networking support.
>> You either want to use pc386 on qemu or arm/zynq on qemu.
>> > I was wondering if this may be the required architecture and simulator
>> > for this project.
>> > Further, I would like to mention, that though this may be an approach
>> > with GSOC in mind, but I wish to end up as a full time contributor for
>> > the RTEMS project in time to come as it suits my taste and past
>> > experience.
>> > Kindly point out things I need to do to proceed and other comments.
>> Eduardo mentioned that this may not be enough to occupy your entire
>> summer. So we would need to identify other work to bundle with this.
>> Monkey for RTEMS should get built as a package inside the RSB. This
>> is like the BSD ports where it always builds from source. Fetch upstream,
>> patch as needed and build for the embedded architecture.
>> Random idea which would need other mentors to buy into. We have an
>> old IPV4 stack in the current tree. We have a newer IPV4/V6 IP stack
>> outside the tree. And there is a working LWIP port. My concept long
>> term has been to divide things into packages:
>> + RTEMS (ok done)
>> + network stack of choice - done for new IPV4/IPV6 stack. current
>>    stack is in tree, would need to be pulled out into its own build
>>    module, LWIP is a candidate for RSB packaging but could get done
>>   by another student as part of BeagleBone work.
>> + network tests - some in the tree, some in network-demos
>> + network servers - ftpd, web servers, telnetd, pppd, etc should be
>>    packages that can be built against your network stack of choice
>> This idea hasn't been reviewed by anyone so would need feedback
>> but conceptually, it makes network services an add-on to the RTEMS
>> core and makes it easier for users to pick a stack. More modular
>> pieces.
>> The first step though is getting Monkey ported as a package. The
>> other steps would need discussing.
>> > Regards
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
> Eduardo Silva
> Monkey Software
> devel mailing list
> devel at rtems.org
