GSOC 2015 Monkey HTTP Server
Eduardo Silva
eduardo at monkey.io
Thu Mar 19 15:57:13 UTC 2015
if there are some application for that project and some accepted student, I
would be glad to sign as a mentor to cover Monkey specifics. Note: we will
need a second mentor to cover RTEMS specifics,
best
On Thu, Mar 19, 2015 at 8:51 AM, Gedare Bloom <gedare at gwu.edu> wrote:
> Eduardo,
> You may like to sign-up as a mentor for RTEMS Project in case the
> student decides to submit an application to port the Monkey server.
> Gedare
> On Thu, Mar 19, 2015 at 8:58 AM, Eduardo Silva <eduardo at monkey.io> wrote:
> > Hi Joel,
> > sorry for the late reply, really busy days :)
> > As you may know we were not selected this time. So how can we help on
> this
> > project ?
> > best
> > On Wed, Mar 11, 2015 at 3:12 PM, Joel Sherrill <
> joel.sherrill at oarcorp.com>
> > wrote:
> >> cc'ing Eduardo Silva from the Monkey project. Eduardo,
> >> you may have to subscribe to get messages back to the
> >> RTEMS list.
> >> On 3/11/2015 3:45 PM, Sujay Raj wrote:
> >> > Hi,
> >> > I am interested in working on porting the Monkey HTTP Server to RTEMS
> >> > as a GSOC project.
> >> > This is the first time I am applying to GSOC and though I have written
> >> > a lot of code, it is also my first attempt at working in an Open
> >> > Source project.
> >> > Some personal projects that I have worked on include developing a
> >> > hobby operating system ( following Bran's Kernel Development Tutorial
> >> > and osdev ), writing ray tracers, as well as porting the nweb web
> >> > server ( 200 lines of C code ) to python ( it was undertaken as an
> >> > exercise to learn more about the functioning and implementation of
> >> > webservers ). Further I have familiarity with x86 assembly (nasm), not
> >> > extraordinary, but fluent.
> >> > I have successfully compiled and executed sample programs for
> >> > sparc-sis but from what I have read sparc-sis doesn't support TCP/IP.
> >> > So I followed the wiki and compiled it for pc386 on QEMU too as it had
> >> > networking support.
> >> You either want to use pc386 on qemu or arm/zynq on qemu.
> >> > I was wondering if this may be the required architecture and simulator
> >> > for this project.
> >> > Further, I would like to mention, that though this may be an approach
> >> > with GSOC in mind, but I wish to end up as a full time contributor for
> >> > the RTEMS project in time to come as it suits my taste and past
> >> > experience.
> >> > Kindly point out things I need to do to proceed and other comments.
> >> Eduardo mentioned that this may not be enough to occupy your entire
> >> summer. So we would need to identify other work to bundle with this.
> >> Monkey for RTEMS should get built as a package inside the RSB. This
> >> is like the BSD ports where it always builds from source. Fetch
> upstream,
> >> patch as needed and build for the embedded architecture.
> >> Random idea which would need other mentors to buy into. We have an
> >> old IPV4 stack in the current tree. We have a newer IPV4/V6 IP stack
> >> outside the tree. And there is a working LWIP port. My concept long
> >> term has been to divide things into packages:
> >> + RTEMS (ok done)
> >> + network stack of choice - done for new IPV4/IPV6 stack. current
> >> stack is in tree, would need to be pulled out into its own build
> >> module, LWIP is a candidate for RSB packaging but could get done
> >> by another student as part of BeagleBone work.
> >> + network tests - some in the tree, some in network-demos
> >> + network servers - ftpd, web servers, telnetd, pppd, etc should be
> >> packages that can be built against your network stack of choice
> >> This idea hasn't been reviewed by anyone so would need feedback
> >> but conceptually, it makes network services an add-on to the RTEMS
> >> core and makes it easier for users to pick a stack. More modular
> >> pieces.
> >> The first step though is getting Monkey ported as a package. The
> >> other steps would need discussing.
> >> > Regards
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
> >> Joel Sherrill, Ph.D. Director of Research & Development
> >> joel.sherrill at OARcorp.com On-Line Applications Research
> >> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> >> Support Available (256) 722-9985
> > Eduardo Silva
> > Monkey Software
> > devel mailing list
> > devel at rtems.org
Eduardo Silva
Monkey Software
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150319/5d30ead0/attachment-0001.html>
