mips/jmr3904 test results
Joel Sherrill
joel.sherrill at oarcorp.com
Sun Mar 29 18:31:49 UTC 2015
Hi
psxkey07, sp37, and sptls01 appear to be real failures.
sp37 - known issue where encoding/decoding of ISR
level in task mode may not make the test happy
sptls01 - I am not sure tls works on MIPS since it
uses a special illegal instruction trap if
I remember correctly.
psxkey07 - resource issue?
spfatal26 - bus fault in simulator which may be
being caught before CPU exception generated.
The spintrcritical* tests may just be an issue with
the simulator setup for clock tick. It just uses
an arbitrary number of instructions per usec and
that may be the issue. Tinkering may fix this or
we could mark them as ignore after investigation.
Passed: 496
Failed: 18
Timeouts: 7
Invalid: 0
Total: 521
Failures:
psxkey07.exe
spintrcritical21.exe
spintrcritical20.exe
spintrcritical10.exe
spintrcritical03.exe
spintrcritical01.exe
spfatal26.exe
spintrcritical09.exe
spintrcritical04.exe
spintrcritical05.exe
sp37.exe
spintrcritical22.exe
sptls01.exe
spintrcritical02.exe
spintrcritical16.exe
spintrcritical23.exe
heapwalk.exe
spintrcritical08.exe
Timeouts:
monitor.exe
capture.exe
top.exe
fileio.exe
termios.exe
crypt01.exe
spcpuset01.exe
Average test time: 0:00:02.073849
Testing time : 0:18:00.475552
-- Joel Sherrill
Ask me about RTEMS: a free RTOS
Support and Training Available
