rtems tester all fails on xilinx_zynq_a9_qemu
Sun Mar 29 20:56:24 UTC 2015
Hi
Even hello fails with both.exe and .ralf files. Something
is fundamentally wrong here. I assume it is the rtems-tester
configuration since it runs with the sim-script. And
it runs with the same qemu command by hand.
Ideas?
~/rtems-4.11-work/rtems-tools/tester/rtems-test
--rtems-tools=/users/joel/rtems-4.11-work/tools/
--rtems-bsp=xilinx_zynq_a9_qemu `find . -name hello.ralf`
RTEMS Testing - Tester, v0.2.0
  Command Line:
/users/joel/rtems-4.11-work/rtems-tools/tester/rtems-test
./arm-rtems4.11/c/xilinx_zynq_a9_qemu/testsuites/samples/hello/hello.ralf
  Python: 2.7.5 (default, Nov  3 2014, 14:26:24) [GCC 4.8.3 20140911
(Red Hat 4.8.3-7)]
[1/1] p:0 f:0 t:0 i:0 | arm/xilinx_zynq_a9_qemu: hello.ralf
 > run: qemu-system-arm -no-reboot -monitor none -serial stdio
-nographic -net none -M xilinx-zynq-a9 -m 256M -kernel
] Warning: nic cadence_gem.0 has no peer
] Warning: nic cadence_gem.1 has no peer
Result: invalid    Time: 0:00:01.008064
Passed:   0
Failed:   0
Timeouts: 0
Invalid:  1
Total:    1
Invalid:
  hello.ralf
Average test time: 0:00:01.503241
Testing time     : 0:00:01.503241
[joel at rtbf64a b-xilinx_zynq_a9_qemu]$ xilinx_zynq_a9_qemu^C
[joel at rtbf64a b-xilinx_zynq_a9_qemu]$ type qemu-system-arm
qemu-system-arm is /users/joel/rtems-4.11-work/tools/bin/qemu-system-arm
