GSoC 2015 - Raspberry Pi improvements
Rohini Kulkarni krohini1593 at gmail.com
Fri Mar 13 16:39:26 UTC 2015
Hi,
I am new to using Raspberry pi. I saw the  READ ME for Raspberry pi BSP. I
have got the files stated there, except the config.txt. I also read some
steps on the Raspberry pi website regarding getting the image onto the SD
card.
Also, I do not understand what the stripping step will do. I need some help
to figure  out booting RTEMS on the board.
Thanks!
On 11 Mar 2015 19:29, "Gedare Bloom" <gedare at gwu.edu> wrote:
> On Wed, Mar 11, 2015 at 9:52 AM, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> > Hi,
> > I am interested in contributing to this project. I referred the page
> > Raspberry Pi improvements and also took a look at the work done under
> > GSoc2013. It would be great if the mentors could help me with some
> queries.
> > [1] Is there any reference for already proposed ideas. On the page Beagle
> > BSP improvements , I saw a list of missing peripherals. Is there such a
> list
> > for Raspberry Pi as well?
> There was an email thread about this recently, see [1]. I think there
> is plenty of work to do.
> > [2] What are the requirements and how should I proceed for this project.
> You need to own a Raspberry Pi, or a Raspberry Pi 2. If you have an
> RPi2, you may consider adding it as a BSP variant and getting SMP
> working on it as a nice project. You should ideally demonstrate that
> you can build the tools and boot RTEMS on the RPi.
> [1] https://lists.rtems.org/pipermail/devel/2015-March/010181.html
> > Thanks!
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150313/2bfd1237/attachment-0002.html>
