[PATCH 15/45] Filesystem: Thread life protection for env changes
Fri May 15 11:41:15 UTC 2015
 cpukit/libcsupport/src/privateenv.c | 20 ++++++++++----------
 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/cpukit/libcsupport/src/privateenv.c b/cpukit/libcsupport/src/privateenv.c
index 5717745..29821e4 100644
--- a/cpukit/libcsupport/src/privateenv.c
+++ b/cpukit/libcsupport/src/privateenv.c
@@ -23,7 +23,7 @@
 #include <rtems/libio_.h>
-#include <rtems/score/threaddispatch.h>
+#include <rtems/score/threadimpl.h>
  *  Instantiate a private user environment for the calling thread.
@@ -50,13 +50,6 @@ void rtems_libio_free_user_env(void *arg)
-static void free_user_env_protected(rtems_user_env_t *env)
-  _Thread_Disable_dispatch();
-  rtems_libio_free_user_env(env);
-  _Thread_Enable_dispatch();
 rtems_status_code rtems_libio_set_private_env(void)
   rtems_status_code sc = RTEMS_SUCCESSFUL;
@@ -64,6 +57,7 @@ rtems_status_code rtems_libio_set_private_env(void)
   bool uses_global_env = old_env == &rtems_global_user_env;
   if (uses_global_env) {
+    bool life_protection = _Thread_Set_life_protection(true);
     rtems_user_env_t *new_env = calloc(1, sizeof(*new_env));
     if (new_env != NULL) {
@@ -83,7 +77,7 @@ rtems_status_code rtems_libio_set_private_env(void)
         if (eno == 0) {
-          free_user_env_protected(old_env);
+          rtems_libio_free_user_env(old_env);
         } else {
           sc = RTEMS_TOO_MANY;
@@ -97,6 +91,8 @@ rtems_status_code rtems_libio_set_private_env(void)
     } else {
       sc = RTEMS_NO_MEMORY;
+    _Thread_Set_life_protection(life_protection);
   return sc;
@@ -108,7 +104,11 @@ void rtems_libio_use_global_env(void)
   bool uses_private_env = env != &rtems_global_user_env;
   if (uses_private_env) {
-    free_user_env_protected(env);
+    rtems_libio_free_user_env(env);
     pthread_setspecific(rtems_current_user_env_key, NULL);
1.8.4.5
