[PATCH 16/45] score: Reduce thread wait states
Fri May 15 11:41:16 UTC 2015
Merge THREAD_WAIT_STATE_SATISFIED, THREAD_WAIT_STATE_TIMEOUT,
THREAD_WAIT_STATE_INTERRUPT_SATISFIED, and
THREAD_WAIT_STATE_INTERRUPT_TIMEOUT into one state
THREAD_WAIT_STATE_READY_AGAIN.  This helps to write generic routines to
block a thread.
Update #2273.
 cpukit/rtems/src/eventsurrender.c             |  4 ++--
 cpukit/rtems/src/eventtimeout.c               |  4 ++--
 cpukit/score/include/rtems/score/thread.h     |  7 ++-----
 cpukit/score/include/rtems/score/threadimpl.h | 25 ++++---------------------
 testsuites/sptests/spintrcritical10/init.c    |  6 +++---
 5 files changed, 13 insertions(+), 33 deletions(-)
diff --git a/cpukit/rtems/src/eventsurrender.c b/cpukit/rtems/src/eventsurrender.c
index e29d203..b740721 100644
--- a/cpukit/rtems/src/eventsurrender.c
+++ b/cpukit/rtems/src/eventsurrender.c
@@ -85,7 +85,7 @@ void _Event_Surrender(
     success = _Thread_Wait_flags_try_change_critical(
       the_thread,
       intend_to_block,
-      wait_class | THREAD_WAIT_STATE_INTERRUPT_SATISFIED
+      wait_class | THREAD_WAIT_STATE_READY_AGAIN
     if ( success ) {
       _Event_Satisfy( the_thread, event, pending_events, seized_events );
@@ -94,7 +94,7 @@ void _Event_Surrender(
       _Thread_Wait_flags_set(
         the_thread,
-        wait_class | THREAD_WAIT_STATE_SATISFIED
       unblock = true;
     } else {
diff --git a/cpukit/rtems/src/eventtimeout.c b/cpukit/rtems/src/eventtimeout.c
index 9c09174..5db118b 100644
--- a/cpukit/rtems/src/eventtimeout.c
+++ b/cpukit/rtems/src/eventtimeout.c
@@ -45,7 +45,7 @@ void _Event_Timeout(
     the_thread,
     intend_to_block,
-    wait_class | THREAD_WAIT_STATE_INTERRUPT_TIMEOUT
   if ( success ) {
@@ -55,7 +55,7 @@ void _Event_Timeout(
     the_thread->Wait.return_code = RTEMS_TIMEOUT;
       the_thread,
-      wait_class | THREAD_WAIT_STATE_TIMEOUT
     unblock = true;
   } else {
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 72e011c..112bd22 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -324,11 +324,8 @@ typedef union {
  * The mutually exclusive wait state flags are
  * - @ref THREAD_WAIT_STATE_INTEND_TO_BLOCK,
- * - @ref THREAD_WAIT_STATE_BLOCKED,
- * - @ref THREAD_WAIT_STATE_SATISFIED,
- * - @ref THREAD_WAIT_STATE_TIMEOUT,
- * - @ref THREAD_WAIT_STATE_INTERRUPT_SATISFIED, and
- * - @ref THREAD_WAIT_STATE_INTERRUPT_TIMEOUT,
+ * - @ref THREAD_WAIT_STATE_BLOCKED, and
+ * - @ref THREAD_WAIT_STATE_READY_AGAIN.
 typedef unsigned int Thread_Wait_flags;
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 84c9ac3..3577a74 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -1138,28 +1138,11 @@ RTEMS_INLINE_ROUTINE void _Thread_Priority_restore_default_change_handler(
 #define THREAD_WAIT_STATE_BLOCKED 0x2U
- * @brief Indicates that the thread progress condition is satisfied and it is
- * ready to resume execution.
-#define THREAD_WAIT_STATE_SATISFIED 0x4U
- * @brief Indicates that a timeout occurred and the thread is ready to resume
- * execution.
-#define THREAD_WAIT_STATE_TIMEOUT 0x8U
- * @brief Indicates that the thread progress condition was satisfied during the
- * blocking operation and it is ready to resume execution.
-#define THREAD_WAIT_STATE_INTERRUPT_SATISFIED 0x10U
- * @brief Indicates that a timeout occurred during the blocking operation and
- * the thread is ready to resume execution.
+ * @brief Indicates that a condition to end the thread wait occurred.
+ * This could be a timeout, a signal, an event or a resource availability.
-#define THREAD_WAIT_STATE_INTERRUPT_TIMEOUT 0x20U
+#define THREAD_WAIT_STATE_READY_AGAIN 0x4U
  * @brief Mask to get the thread wait class flags.
diff --git a/testsuites/sptests/spintrcritical10/init.c b/testsuites/sptests/spintrcritical10/init.c
index 441b161..e9f813d 100644
--- a/testsuites/sptests/spintrcritical10/init.c
+++ b/testsuites/sptests/spintrcritical10/init.c
@@ -88,7 +88,7 @@ static void any_satisfy_before_timeout(rtems_id timer, void *arg)
     if (ctx->hit) {
       rtems_test_assert(
         _Thread_Wait_flags_get(thread)
-          == (THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_INTERRUPT_SATISFIED)
+          == (THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_READY_AGAIN)
@@ -185,7 +185,7 @@ static void all_satisfy_before_timeout(rtems_id timer, void *arg)
     if (ctx->hit) {
       rtems_test_assert(
@@ -269,7 +269,7 @@ static void timeout_before_satisfied(rtems_id timer, void *arg)
     if (ctx->hit) {
       rtems_test_assert(
-          == (THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_INTERRUPT_TIMEOUT)
1.8.4.5
