[PATCH 17/45] score: Generalize _Event_Timeout()
Fri May 15 11:41:17 UTC 2015
Add a thread wait timeout code.  Replace _Event_Timeout() with a general
purpose _Thread_Timeout() watchdog handler.
Update #2273.
 cpukit/rtems/Makefile.am                      |  1 -
 cpukit/rtems/src/eventseize.c                 |  8 ++-
 cpukit/rtems/src/eventtimeout.c               | 70 -------------------------
 cpukit/score/Makefile.am                      |  1 +
 cpukit/score/include/rtems/score/thread.h     |  5 ++
 cpukit/score/include/rtems/score/threadimpl.h | 22 ++++++++
 cpukit/score/src/threadtimeout.c              | 74 +++++++++++++++++++++++++++
 testsuites/sptests/spintrcritical10/init.c    |  6 +--
 8 files changed, 112 insertions(+), 75 deletions(-)
 delete mode 100644 cpukit/rtems/src/eventtimeout.c
 create mode 100644 cpukit/score/src/threadtimeout.c
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index 5e6f2ea..084b39f 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -210,7 +210,6 @@ librtems_a_SOURCES += src/eventreceive.c
 librtems_a_SOURCES += src/eventseize.c
 librtems_a_SOURCES += src/eventsend.c
 librtems_a_SOURCES += src/eventsurrender.c
-librtems_a_SOURCES += src/eventtimeout.c
 librtems_a_SOURCES += src/systemeventsend.c
 librtems_a_SOURCES += src/systemeventreceive.c
diff --git a/cpukit/rtems/src/eventseize.c b/cpukit/rtems/src/eventseize.c
index 36b1964..6611a8d 100644
--- a/cpukit/rtems/src/eventseize.c
+++ b/cpukit/rtems/src/eventseize.c
@@ -89,7 +89,13 @@ void _Event_Seize(
   _Giant_Acquire( cpu_self );
   if ( ticks ) {
-    _Watchdog_Initialize( &executing->Timer, _Event_Timeout, 0, executing );
+    _Thread_Wait_set_timeout_code( executing, RTEMS_TIMEOUT );
+    _Watchdog_Initialize(
+      &executing->Timer,
+      _Thread_Timeout,
+      0,
+      executing
     _Watchdog_Insert_ticks( &executing->Timer, ticks );
diff --git a/cpukit/rtems/src/eventtimeout.c b/cpukit/rtems/src/eventtimeout.c
deleted file mode 100644
index 5db118b..0000000
--- a/cpukit/rtems/src/eventtimeout.c
+++ /dev/null
@@ -1,70 +0,0 @@
- *  @file
- *  @brief Timeout Event
- *  @ingroup ClassicEvent
- *  COPYRIGHT (c) 1989-2008.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-  #include "config.h"
-#endif
-#include <rtems/rtems/eventimpl.h>
-#include <rtems/score/threadimpl.h>
-void _Event_Timeout(
-  Objects_Id  id,
-  void       *arg
-  Thread_Control    *the_thread;
-  ISR_lock_Context   lock_context;
-  Thread_Wait_flags  wait_flags;
-  Thread_Wait_flags  wait_class;
-  Thread_Wait_flags  intend_to_block;
-  Thread_Wait_flags  blocked;
-  bool               success;
-  bool               unblock;
-  the_thread = arg;
-  _Thread_Lock_acquire_default( the_thread, &lock_context );
-  wait_flags = _Thread_Wait_flags_get( the_thread );
-  wait_class = wait_flags & THREAD_WAIT_CLASS_MASK;
-  intend_to_block = wait_class | THREAD_WAIT_STATE_INTEND_TO_BLOCK;
-  blocked = wait_class | THREAD_WAIT_STATE_BLOCKED;
-  success = _Thread_Wait_flags_try_change_critical(
-    the_thread,
-    intend_to_block,
-    wait_class | THREAD_WAIT_STATE_READY_AGAIN
-  if ( success ) {
-    the_thread->Wait.return_code = RTEMS_TIMEOUT;
-    unblock = false;
-  } else if ( _Thread_Wait_flags_get( the_thread ) == blocked ) {
-    _Thread_Wait_flags_set(
-      the_thread,
-    unblock = true;
-  } else {
-    unblock = false;
-  _Thread_Lock_release_default( the_thread, &lock_context );
-  if ( unblock ) {
-    _Thread_Unblock( the_thread );
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 3eb2caa..3547097 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -290,6 +290,7 @@ libscore_a_SOURCES += src/thread.c src/threadchangepriority.c \
     src/threadstackallocate.c src/threadstackfree.c src/threadstart.c \
     src/threadstartmultitasking.c src/iterateoverthreads.c
 libscore_a_SOURCES += src/threadglobalconstruction.c
+libscore_a_SOURCES += src/threadtimeout.c
 libscore_a_SOURCES += src/threadyield.c
 if HAS_SMP
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 112bd22..1a73fda 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -354,6 +354,11 @@ typedef struct {
   uint32_t              return_code;
+   * @brief Code to set the timeout return code in _Thread_Timeout().
+  uint32_t timeout_code;
   /** This field points to the thread queue on which this thread is blocked. */
   Thread_queue_Control *queue;
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 3577a74..c266a9c 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -1257,6 +1257,28 @@ RTEMS_INLINE_ROUTINE bool _Thread_Wait_flags_try_change(
   return success;
+ * @brief Sets the thread wait timeout code.
+ * @param[in] the_thread The thread.
+ * @param[in] timeout_code The new thread wait timeout code.
+RTEMS_INLINE_ROUTINE void _Thread_Wait_set_timeout_code(
+  Thread_Control *the_thread,
+  the_thread->Wait.timeout_code = timeout_code;
+ * @brief General purpose thread wait timeout.
+ * @param[in] id Unused.
+ * @param[in] arg The thread.
+void _Thread_Timeout( Objects_Id id, void *arg );
 RTEMS_INLINE_ROUTINE void _Thread_Debug_set_real_processor(
   Per_CPU_Control *cpu
diff --git a/cpukit/score/src/threadtimeout.c b/cpukit/score/src/threadtimeout.c
new file mode 100644
index 0000000..b6ce2d7
--- /dev/null
+++ b/cpukit/score/src/threadtimeout.c
@@ -0,0 +1,74 @@
+ * @file
+ * @brief Thread Wait Timeout
+ * @ingroup ScoreThread
+ *  COPYRIGHT (c) 1989-2008.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/score/threadimpl.h>
+static void _Thread_Do_timeout( Thread_Control *the_thread )
+  the_thread->Wait.return_code = the_thread->Wait.timeout_code;
+  _Thread_Lock_restore_default( the_thread );
+  Thread_Control    *the_thread;
+  ISR_lock_Control  *thread_lock;
+  ISR_lock_Context   lock_context;
+  Thread_Wait_flags  wait_flags;
+  Thread_Wait_flags  wait_class;
+  Thread_Wait_flags  intend_to_block;
+  Thread_Wait_flags  blocked;
+  bool               success;
+  bool               unblock;
+  the_thread = arg;
+  thread_lock = _Thread_Lock_acquire( the_thread, &lock_context );
+  wait_flags = _Thread_Wait_flags_get( the_thread );
+  wait_class = wait_flags & THREAD_WAIT_CLASS_MASK;
+  intend_to_block = wait_class | THREAD_WAIT_STATE_INTEND_TO_BLOCK;
+  blocked = wait_class | THREAD_WAIT_STATE_BLOCKED;
+  success = _Thread_Wait_flags_try_change_critical(
+    the_thread,
+    intend_to_block,
+    wait_class | THREAD_WAIT_STATE_READY_AGAIN
+  if ( success ) {
+    _Thread_Do_timeout( the_thread );
+    unblock = false;
+  } else if ( _Thread_Wait_flags_get( the_thread ) == blocked ) {
+    _Thread_Wait_flags_set(
+      the_thread,
+    unblock = true;
+  } else {
+    unblock = false;
+  _Thread_Lock_release( thread_lock, &lock_context );
+  if ( unblock ) {
+    _Thread_Unblock( the_thread );
diff --git a/testsuites/sptests/spintrcritical10/init.c b/testsuites/sptests/spintrcritical10/init.c
index e9f813d..e4a2a94 100644
--- a/testsuites/sptests/spintrcritical10/init.c
+++ b/testsuites/sptests/spintrcritical10/init.c
@@ -78,7 +78,7 @@ static void any_satisfy_before_timeout(rtems_id timer, void *arg)
     rtems_test_assert(thread->Wait.return_code == RTEMS_SUCCESSFUL);
-    _Event_Timeout(0, thread);
+    _Thread_Timeout(0, thread);
     rtems_test_assert(
       *(rtems_event_set *) thread->Wait.return_argument == GREEN
@@ -175,7 +175,7 @@ static void all_satisfy_before_timeout(rtems_id timer, void *arg)
     rtems_test_assert(
       *(rtems_event_set *) thread->Wait.return_argument == EVENTS
@@ -251,7 +251,7 @@ static void timeout_before_satisfied(rtems_id timer, void *arg)
     rtems_test_assert(
       *(rtems_event_set *) thread->Wait.return_argument == DEADBEEF
1.8.4.5
