Major SMP Improvements
Cudmore, Alan P. (GSFC-5820) alan.p.cudmore at nasa.gov
Fri May 15 13:11:21 UTC 2015
This does sound like a nice improvement. I would also like to put in my
vote for stable SMP on the LEON for 4.11.
Thanks,
Alan
On 5/15/15, 9:01 AM, "Daniel Hellstrom" <daniel at gaisler.com> wrote:
>Hello Sebastian,
>Thanks for your work! I havn't looked at your work but I have some
>comments.
>On 05/15/2015 01:41 PM, Sebastian Huber wrote:
>> https://devel.rtems.org/ticket/2130
>> https://devel.rtems.org/ticket/2131
>> https://devel.rtems.org/ticket/2271
>> https://devel.rtems.org/ticket/2273
>> https://devel.rtems.org/ticket/2307
>> It provides a major performance boost for SMP configurations, see
>> https://devel.rtems.org/ticket/2271 and
>>https://devel.rtems.org/ticket/2273.
>> It was tested on the Altera Cyclone V, ESA/Gaisler NGMP and Freescale
>>T4240
>> platforms using the standard RTEMS testsuite, a randomized test case
>>that
>> covers the thread queue and watchdog implementation (it run several
>>days) and
>> with heavy load network traffic using the new network stack (it uses
>>hundreds
>> of locks). After two years of work all tests pass now on the NGMP
>>platform in
>> uni-processor and SMP configurations.
>Sound very promising.
>> The BSPs compile and link the samples using the latest RSB based tool
>>chain
>> (except targets with a broken compiler, e.g. AVR, Moxie).
>> With this patch set the SMP support of RTEMS can be considered to be
>> practically useful on targets with more than two processors.  This is
>> definitely not the case for the current Git master (possible RTEMS
>>4.11).  Also
>> timestamps are broken on SMP in the current Git master.  So it may make
>>sense
>> to include this patch set in the RTEMS 4.11 release.  We don't have
>>additional
>> RTEMS work in the next three months planned so this is the last big
>>change set
>> for a while.
>I just want to confirm this issue with the master branch. In order to use
>it on LEON in SMP configuration we had to make a hack in cpukit code to
>call the LEON timer code to make it work. It would of
>course be nice to have a fix for this in 4.11.
>Daniel
>_______________________________________________
>devel mailing list
>devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/devel
