Major SMP Improvements
Sat May 16 01:14:36 UTC 2015
On 15/05/2015 11:01 pm, Daniel Hellstrom wrote:
> I just want to confirm this issue with the master branch. In order to
> use it on LEON in SMP configuration we had to make a hack in cpukit code
> to call the LEON timer code to make it work. It would of course be nice
> to have a fix for this in 4.11.
Please create a ticket and select a severity level you feel it needs.
There is blocker if you feel this is the case.
