Major SMP Improvements
Daniel Hellstrom
daniel at gaisler.com
Sat May 16 06:44:36 UTC 2015
Hi Chris,
I thought this was publicaly known and that Sebastian's ticket was the way to fix it. There was a discussion about it when it was discovered around Aug 2014, and I agreed then that Sebastian's path to fixing it sounded very good but I dont know all aspects of it. As I recall its not a blocker for Leon smp, because of the dirty fix required for smp.
Daniel
On 16 May 2015 03:14:36 CEST, Chris Johns <chrisj at rtems.org> wrote:
>On 15/05/2015 11:01 pm, Daniel Hellstrom wrote:
>> I just want to confirm this issue with the master branch. In order to
>> use it on LEON in SMP configuration we had to make a hack in cpukit
>code
>> to call the LEON timer code to make it work. It would of course be
>nice
>> to have a fix for this in 4.11.
>Please create a ticket and select a severity level you feel it needs.
>There is blocker if you feel this is the case.
>Chris
Sent from my Android phone with K-9 Mail. Please excuse my brevity.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150516/8f8a024f/attachment.html>
