[PATCH 41/45] timecounter: Use uint32_t instead of u_int
Mon May 18 07:50:13 UTC 2015
On 17/05/15 15:22, Gedare Bloom wrote:
> On Fri, May 15, 2015 at 7:47 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> From: Alexander Krutwig <alexander.krutwig at embedded-brains.de>
>> FreeBSD assumes that u_int is a 32-bit integer type.  This is wrong for
>> some 16-bit targets supported by RTEMS.
>> Update #2271.
> Can we undef u_int and redefine it to uint32_t instead? This will be a
> more localized RTEMS-specific change.
I think this is very confusing.  This patch is separate since we try to
submit it to FreeBSD.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
