[PATCH 41/45] timecounter: Use uint32_t instead of u_int
Gedare Bloom gedare at gwu.edu
Mon May 18 14:00:57 UTC 2015
On Mon, May 18, 2015 at 3:50 AM, Sebastian Huber
> On 17/05/15 15:22, Gedare Bloom wrote:
>> On Fri, May 15, 2015 at 7:47 AM, Sebastian Huber
>>> From: Alexander Krutwig <alexander.krutwig at embedded-brains.de>
>>> FreeBSD assumes that u_int is a 32-bit integer type.  This is wrong for
>>> some 16-bit targets supported by RTEMS.
>>> Update #2271.
>> Can we undef u_int and redefine it to uint32_t instead? This will be a
>> more localized RTEMS-specific change.
> I think this is very confusing.  This patch is separate since we try to
> submit it to FreeBSD.
OK that works better.
> devel mailing list
> devel at rtems.org
