tms570 warning on master
Thu May 21 15:38:16 UTC 2015
Thanks.
I am cranking through configurations.
Does libbsd still build for all architectures? I haven't tried that in a
while
but it did at one point.
On 5/21/2015 10:33 AM, Sebastian Huber wrote:
> Hello,
> sorry, should be fixed now.
> ----- Joel Sherrill <joel.sherrill at oarcorp.com> schrieb:
>> Hi
>> I thought I sent this yesterday but just found the window minimized.
>> So far, this is the only warning not covered by my patch set.
>>      1
>> log/arm-tms570ls3137_hdk_sdram.log:../../../../../../../../rtems/c/src/lib/libbsp/arm/tms570/clock/clock.c:77:34:
>> warning: assignment from incompatible pointer type
>>       1
>> log/arm-tms570ls3137_hdk.log:../../../../../../../../rtems/c/src/lib/libbsp/arm/tms570/clock/clock.c:77:34:
>>       1
>> log/arm-tms570ls3137_hdk_intram.log:../../../../../../../../rtems/c/src/lib/libbsp/arm/tms570/clock/clock.c:77:34:
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
