Release repos
Wed May 27 14:25:32 UTC 2015
On 5/27/2015 9:06 AM, Gedare Bloom wrote:
> I want to clarify what repos need to be synchronized (or eventually
> tagged) with an RTEMS release. Currently we know (from [1]) the
> following must:
> rtems
> examples-v2
> network-demos
> rtems-testing
> rtems-tools
> rtems-source-builder
> We don't know about:
> rtems-libbsd
> rtems-addon-packages
I would like to avoid including this. I have patches ready and it
does build for all. But I am hoping to get the packages into RSB
and eliminate it.
> rtems-graphics-toolkit
I haven't done any test builds on this.
> My suspicion is that libbsd should get a tag or branch for a release,
> in case updates/new features added to it can break the release build.
> Advice?
I am also suspicious that it needs to be in sync with tool and RTEMS .h
files.
> It would also be good to eventually get tags for versions of the addon
> and graphics toolkit that are "good" for a release also, to dissociate
> any further developments. Alternately, we should avoid introducing
> regressions to those repos that cause breakage with
> released/maintained versions of RTEMS, i.e. 4.10 and 4.11 after this
> release.
> Did I miss any?
> Gedare
> [1] https://devel.rtems.org/wiki/Developer/Release#RTEMSReleaseRepositories
> devel mailing list
> devel at rtems.org
