[rtems commit] tmtests/tm26: Avoid NULL pointer access
Fri May 29 14:25:21 UTC 2015
On 5/29/2015 8:37 AM, Sebastian Huber wrote:
> Module:    rtems
> Branch:    master
> Commit:    5611839a7e2e371dd1f327c336c785095f634e55
> Changeset: http://git.rtems.org/rtems/commit/?id=5611839a7e2e371dd1f327c336c785095f634e55
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Fri May 29 14:18:32 2015 +0200
>   testsuites/tmtests/tm26/task1.c | 3 ---
>   1 file changed, 3 deletions(-)
> diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
> index 6cec7da..ee66218 100644
> --- a/testsuites/tmtests/tm26/task1.c
> +++ b/testsuites/tmtests/tm26/task1.c
> @@ -439,9 +439,6 @@ rtems_task Low_task(
>     thread_disable_dispatch();
>     benchmark_timer_initialize();
> -#if (CPU_HARDWARE_FP == 1) || (CPU_SOFTWARE_FP == 1)
> -    _Context_Restore_fp( &_Thread_Get_executing()->fp_context );
> -#endif
What impact does this have on the case being timed?
How did this fault? What configuration?
>       _Context_Switch(
>         &executing->Registers,
>         &_Thread_Get_executing()->Registers
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
