Trouble building RTEMS from master (TMS570 and LPC1768)
Martin Galvan martin.galvan at tallertechnologies.com
Thu Nov 5 13:29:06 UTC 2015
On Wed, Nov 4, 2015 at 7:33 PM, Pavel Pisa <pisa at cmp.felk.cvut.cz> wrote:
> So it is important what are intended use cases.
> The one where RTEMS image starts from address 0
> is simple and should no use POM nor VIM interrupt bypassing.
> But it requires integration with HAL startup for now.
This should probably go on a separate thread.
Anyway, what we're doing right now is simply removing any calls to
tms570_pom_remap from the startup code. I was planning on adding some
way for the tms570ls3137_hdk BSP not to call that function (probably
using an #ifdef or something like that).
What did the TI guys told you?
