Trouble building RTEMS from master
Joel Sherrill
joel at rtems.org
Wed Nov 4 21:59:15 UTC 2015
On Nov 4, 2015 1:57 PM, "Gedare Bloom" <gedare at rtems.org> wrote:
> Did you bootstrap -c and then bootstrap? I think I saw this error
> earlier today too, with a new sparc toolchain, but then it went away
> after i rm-rf'd my build tree and tried over.
Hmm.. I thought I did that but am not sure. Maybe Martin can confirm.
> On Wed, Nov 4, 2015 at 4:39 PM, Martin Galvan
> <martin.galvan at tallertechnologies.com> wrote:
> > Hi everyone! I'm currently having some trouble when building RTEMS
> > from the git mainline. I'm using a toolchain built using (a fairly
> > recent) RSB. My configure is:
> > ../source/configure --target=arm-rtems4.11
> > --enable-rtemsbsp=beagleboneblack --enable-posix --enable-cxx
> > --disable-networking --enable-tests=no
> > However, when I run make, I get this:
> > make[1]: *** No rule to make target `make/Templates/Makefile.lib',
> > needed by `all-am'. Stop.
> > I tried re-bootstraping and still see the same error. I saw this on a
> > couple more BSPs (TMS570 and LPC1768).
> > Notice this happens only with master; the 4.11 branch builds ok.
> > Is this a bug, or am I doing something wrong?
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151104/42a4175d/attachment.html>
