[rtems-libbsd commit] builder.py: addTargetSourceCPUDependentSourceFiles
Thu Oct 1 20:34:29 UTC 2015
On 2/10/2015 9:15 am, Joel Sherrill wrote:
> On 10/1/2015 2:38 PM, Chris Johns wrote:
>> On 2/10/2015 8:33 am, Sebastian Huber wrote:
>>> Why do you think it is wrong?
>> Because the check is for 'arm' and the file is 'mips'.
> If I recall correctly, the MIPS version is the most generic
> version and it is used for architectures which don't have
> their own.
<shudder>
Is this how FreeBSD uses the code?
> But with this change, that should be checked to be sure
> and comments added.
I suppose no one can change the mips code which means that name is
meaning less as well.
