[PATCH] Fixes GPIO APIs Naming Convention and Comments
sudarshan.rajagopalan sudarshan.rajagopalan at vecna.com
Mon Oct 12 17:37:27 UTC 2015
Just found few function names to be inconsistent towards the naming
convention, and also few API documentation in the RTEMS GPIO files.
Please commit this if required.
Thanks and Regards,
Sudarshan Rajagopalan
 From e17ce266ba4cfaec0159c5477697847629946ced Mon Sep 17 00:00:00 2001
 From: Sudarshan Rajagopalan <sudarshan.rajagopalan at vecna.com>
Date: Mon, 12 Oct 2015 12:47:35 -0400
Subject: [PATCH] Fixes GPIO APIs Naming Convention and Comments
  c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c      |  8 ++++----
  c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c |  4 ++--
  c/src/lib/libbsp/shared/gpio.c                   |  6 +++---
  c/src/lib/libbsp/shared/include/gpio.h           | 20
  4 files changed, 21 insertions(+), 17 deletions(-)
diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
index 8cf690f..9737dec 100644
--- a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
+++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
@@ -299,7 +299,7 @@ uint32_t
rtems_gpio_bsp_interrupt_line(rtems_vector_number vector)
    return event_status;
-rtems_status_code rtems_bsp_enable_interrupt(
+rtems_status_code rtems_gpio_bsp_enable_interrupt(
    uint32_t bank,
    uint32_t pin,
    rtems_gpio_interrupt interrupt
@@ -354,7 +354,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
    return RTEMS_SUCCESSFUL;
-rtems_status_code rtems_bsp_disable_interrupt(
+rtems_status_code rtems_gpio_bsp_disable_interrupt(
    uint32_t bank,
    uint32_t pin,
@@ -528,7 +528,7 @@ uint32_t
    return -1;
    uint32_t bank,
    uint32_t pin,
@@ -536,7 +536,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
    return RTEMS_NOT_DEFINED;
    uint32_t bank,
    uint32_t pin,
diff --git a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
index a782d11..4fb2c93 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
@@ -183,7 +183,7 @@ uint32_t
    uint32_t bank,
    uint32_t pin,
@@ -227,7 +227,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
    uint32_t bank,
    uint32_t pin,
diff --git a/c/src/lib/libbsp/shared/gpio.c
b/c/src/lib/libbsp/shared/gpio.c
index 80e2727..b806556 100644
--- a/c/src/lib/libbsp/shared/gpio.c
+++ b/c/src/lib/libbsp/shared/gpio.c
@@ -1341,7 +1341,7 @@ rtems_status_code rtems_gpio_request_pin(
          return RTEMS_UNSATISFIED;
-      sc = rtems_bsp_select_specific_io(
+      sc = rtems_gpio_bsp_select_specific_io(
               bank,
               pin,
               bsp_data->io_function,
@@ -1805,7 +1805,7 @@ rtems_status_code rtems_gpio_enable_interrupt(
-  sc = rtems_bsp_enable_interrupt(bank, pin, interrupt);
+  sc = rtems_gpio_bsp_enable_interrupt(bank, pin, interrupt);
    if ( sc != RTEMS_SUCCESSFUL ) {
      RELEASE_LOCK(gpio_bank_state[bank].lock);
@@ -1919,7 +1919,7 @@ rtems_status_code
rtems_gpio_disable_interrupt(uint32_t pin_number)
      return RTEMS_NOT_CONFIGURED;
-  sc = rtems_bsp_disable_interrupt(bank, pin,
interrupt_state->active_interrupt);
+  sc = rtems_gpio_bsp_disable_interrupt(bank, pin,
diff --git a/c/src/lib/libbsp/shared/include/gpio.h
b/c/src/lib/libbsp/shared/include/gpio.h
index 54de5f1..7d8f67b 100644
--- a/c/src/lib/libbsp/shared/include/gpio.h
+++ b/c/src/lib/libbsp/shared/include/gpio.h
@@ -736,12 +736,16 @@ extern uint32_t rtems_gpio_bsp_multi_read(uint32_t
bank, uint32_t bitmask);
   *        does not support the feature, by returning RTEMS_NOT_DEFINED.
   * @param[in] bank GPIO bank number.
- * @param[in] bitmask Bitmask of GPIO pins to clear in the given bank.
+ * @param[in] pins Array filled with BSP specific pin numbers. All pins
belong
+ *                 to the same select bank.
+ * @param[in] pin_count Number of pin configurations in the @var pins
array.
+ * @param[in] arg Pointer to a BSP defined structure with BSP-specific
+ *                data. This field is handled by the BSP.
- * @retval RTEMS_SUCCESSFUL All pins were cleared successfully.
- * @retval RTEMS_NOT_DEFINED The BSP does not support BSP specific
operations
- *                           for groups.
- * @retval RTEMS_UNSATISFIED Could not clear at least one of the pins.
+ * @retval RTEMS_SUCCESSFUL Operation completed with success.
+ * @retval RTEMS_NOT_DEFINED Group has no BSP specific pins, or the BSP
does not
+ *                           support BSP specific operations for
groups.
+ * @retval RTEMS_UNSATISFIED Could not operate on at least one of the
pins.
  extern rtems_status_code rtems_gpio_bsp_specific_group_operation(
    uint32_t bank,
@@ -859,7 +863,7 @@ extern rtems_status_code
rtems_gpio_bsp_select_output(
   * @retval RTEMS_SUCCESSFUL Function was assigned successfully.
   * @retval RTEMS_UNSATISFIED Could not assign the function to the pin.
-extern rtems_status_code rtems_bsp_select_specific_io(
+extern rtems_status_code rtems_gpio_bsp_select_specific_io(
    uint32_t bank,
    uint32_t pin,
    uint32_t function,
@@ -918,7 +922,7 @@ extern rtems_vector_number
rtems_gpio_bsp_get_vector(uint32_t bank);
   * @retval RTEMS_SUCCESSFUL Interrupt successfully enabled for this
pin.
   * @retval RTEMS_UNSATISFIED Could not enable the interrupt on the pin.
-extern rtems_status_code rtems_bsp_enable_interrupt(
+extern rtems_status_code rtems_gpio_bsp_enable_interrupt(
    uint32_t bank,
    uint32_t pin,
@@ -935,7 +939,7 @@ extern rtems_status_code rtems_bsp_enable_interrupt(
   * @retval RTEMS_SUCCESSFUL Interrupt successfully disabled for this
pin.
   * @retval RTEMS_UNSATISFIED Could not disable interrupts on this pin.
-extern rtems_status_code rtems_bsp_disable_interrupt(
+extern rtems_status_code rtems_gpio_bsp_disable_interrupt(
    uint32_t bank,
    uint32_t pin,
1.9.1
Type: text/x-c
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151012/b418c6d5/attachment.bin>
