[PATCH] Fixes GPIO APIs Naming Convention and Comments
André Marques
andre.lousa.marques at gmail.com
Mon Oct 12 20:07:16 UTC 2015
Hello Sudarshan,
Às 18:37 de 12-10-2015, sudarshan.rajagopalan escreveu:
> Just found few function names to be inconsistent towards the naming
> convention, and also few API documentation in the RTEMS GPIO files.
> Please commit this if required.
Thanks for the patch! I noticed that some functions were missing the
_gpio_ before but forgot about it completely.
I will also update my GSOC documentation wiki page and test cases when
someone commits this.
On another note (speaking to the community) maybe my GPIO documentation
could be moved (and improved in the way) to the user manual?
> Thanks and Regards,
> Sudarshan Rajagopalan
> From e17ce266ba4cfaec0159c5477697847629946ced Mon Sep 17 00:00:00 2001
> From: Sudarshan Rajagopalan <sudarshan.rajagopalan at vecna.com>
> Date: Mon, 12 Oct 2015 12:47:35 -0400
> Subject: [PATCH] Fixes GPIO APIs Naming Convention and Comments
> c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c | 8 ++++----
> c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c | 4 ++--
> c/src/lib/libbsp/shared/gpio.c | 6 +++---
> c/src/lib/libbsp/shared/include/gpio.h | 20
> 4 files changed, 21 insertions(+), 17 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
> b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
> index 8cf690f..9737dec 100644
> --- a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
> +++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
> @@ -299,7 +299,7 @@ uint32_t
> rtems_gpio_bsp_interrupt_line(rtems_vector_number vector)
> return event_status;
> -rtems_status_code rtems_bsp_enable_interrupt(
> +rtems_status_code rtems_gpio_bsp_enable_interrupt(
> uint32_t bank,
> uint32_t pin,
> rtems_gpio_interrupt interrupt
> @@ -354,7 +354,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
> return RTEMS_SUCCESSFUL;
> -rtems_status_code rtems_bsp_disable_interrupt(
> +rtems_status_code rtems_gpio_bsp_disable_interrupt(
> uint32_t bank,
> uint32_t pin,
> @@ -528,7 +528,7 @@ uint32_t
> return -1;
> uint32_t bank,
> uint32_t pin,
> @@ -536,7 +536,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
> return RTEMS_NOT_DEFINED;
> uint32_t bank,
> uint32_t pin,
> diff --git a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
> b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
> index a782d11..4fb2c93 100644
> --- a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
> +++ b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
> @@ -183,7 +183,7 @@ uint32_t
> uint32_t bank,
> uint32_t pin,
> @@ -227,7 +227,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
> uint32_t bank,
> uint32_t pin,
> diff --git a/c/src/lib/libbsp/shared/gpio.c
> b/c/src/lib/libbsp/shared/gpio.c
> index 80e2727..b806556 100644
> --- a/c/src/lib/libbsp/shared/gpio.c
> +++ b/c/src/lib/libbsp/shared/gpio.c
> @@ -1341,7 +1341,7 @@ rtems_status_code rtems_gpio_request_pin(
> return RTEMS_UNSATISFIED;
> - sc = rtems_bsp_select_specific_io(
> + sc = rtems_gpio_bsp_select_specific_io(
> bank,
> pin,
> bsp_data->io_function,
> @@ -1805,7 +1805,7 @@ rtems_status_code rtems_gpio_enable_interrupt(
> - sc = rtems_bsp_enable_interrupt(bank, pin, interrupt);
> + sc = rtems_gpio_bsp_enable_interrupt(bank, pin, interrupt);
> if ( sc != RTEMS_SUCCESSFUL ) {
> RELEASE_LOCK(gpio_bank_state[bank].lock);
> @@ -1919,7 +1919,7 @@ rtems_status_code
> rtems_gpio_disable_interrupt(uint32_t pin_number)
> return RTEMS_NOT_CONFIGURED;
> - sc = rtems_bsp_disable_interrupt(bank, pin,
> interrupt_state->active_interrupt);
> + sc = rtems_gpio_bsp_disable_interrupt(bank, pin,
> diff --git a/c/src/lib/libbsp/shared/include/gpio.h
> b/c/src/lib/libbsp/shared/include/gpio.h
> index 54de5f1..7d8f67b 100644
> --- a/c/src/lib/libbsp/shared/include/gpio.h
> +++ b/c/src/lib/libbsp/shared/include/gpio.h
> @@ -736,12 +736,16 @@ extern uint32_t
> rtems_gpio_bsp_multi_read(uint32_t bank, uint32_t bitmask);
> * does not support the feature, by returning RTEMS_NOT_DEFINED.
> * @param[in] bank GPIO bank number.
> - * @param[in] bitmask Bitmask of GPIO pins to clear in the given bank.
> + * @param[in] pins Array filled with BSP specific pin numbers. All
> pins belong
> + * to the same select bank.
> + * @param[in] pin_count Number of pin configurations in the @var pins
> array.
> + * @param[in] arg Pointer to a BSP defined structure with BSP-specific
> + * data. This field is handled by the BSP.
> - * @retval RTEMS_SUCCESSFUL All pins were cleared successfully.
> - * @retval RTEMS_NOT_DEFINED The BSP does not support BSP specific
> operations
> - * for groups.
> - * @retval RTEMS_UNSATISFIED Could not clear at least one of the pins.
> + * @retval RTEMS_SUCCESSFUL Operation completed with success.
> + * @retval RTEMS_NOT_DEFINED Group has no BSP specific pins, or the
> BSP does not
> + * support BSP specific operations for groups.
> + * @retval RTEMS_UNSATISFIED Could not operate on at least one of the
> pins.
> extern rtems_status_code rtems_gpio_bsp_specific_group_operation(
> uint32_t bank,
> @@ -859,7 +863,7 @@ extern rtems_status_code
> rtems_gpio_bsp_select_output(
> * @retval RTEMS_SUCCESSFUL Function was assigned successfully.
> * @retval RTEMS_UNSATISFIED Could not assign the function to the pin.
> -extern rtems_status_code rtems_bsp_select_specific_io(
> +extern rtems_status_code rtems_gpio_bsp_select_specific_io(
> uint32_t bank,
> uint32_t pin,
> uint32_t function,
> @@ -918,7 +922,7 @@ extern rtems_vector_number
> rtems_gpio_bsp_get_vector(uint32_t bank);
> * @retval RTEMS_SUCCESSFUL Interrupt successfully enabled for this pin.
> * @retval RTEMS_UNSATISFIED Could not enable the interrupt on the pin.
> -extern rtems_status_code rtems_bsp_enable_interrupt(
> +extern rtems_status_code rtems_gpio_bsp_enable_interrupt(
> uint32_t bank,
> uint32_t pin,
> @@ -935,7 +939,7 @@ extern rtems_status_code rtems_bsp_enable_interrupt(
> * @retval RTEMS_SUCCESSFUL Interrupt successfully disabled for this
> pin.
> * @retval RTEMS_UNSATISFIED Could not disable interrupts on this pin.
> -extern rtems_status_code rtems_bsp_disable_interrupt(
> +extern rtems_status_code rtems_gpio_bsp_disable_interrupt(
> uint32_t bank,
> uint32_t pin,
> devel mailing list
> devel at rtems.org
--André Marques.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151012/06981dda/attachment-0001.html>
