[PATCH] Fixes GPIO APIs Naming Convention and Comments
sudarshan.rajagopalan sudarshan.rajagopalan at vecna.com
Wed Oct 14 21:06:55 UTC 2015
On 2015-10-14 16:28, Gedare Bloom wrote:
> OK to commit, but the patch did not apply cleanly for me, something
> wrong with the mail message.
Hi Gedare,
The mail message was not sent using git send-email (this is not working
for us currently), so I copied the contents of the patch to this mail
message. Could you try using the patch attached in my first mail?
Also, does this require a ticket?
Thanks and Regards,
Sudarshan
> On Tue, Oct 13, 2015 at 3:11 AM, Ben Gras <beng at shrike-systems.com>
> wrote:
>> All,
>> This change renames these gpio-specific functions:
>> rtems_bsp_enable_interrupt
>> rtems_bsp_disable_interrupt
>> rtems_bsp_select_specific_io
>> to
>> rtems_gpio_bsp_enable_interrupt
>> rtems_gpio_bsp_disable_interrupt
>> rtems_gpio_bsp_select_specific_io
>> +1, Definitely an improvement.
>> On Mon, Oct 12, 2015 at 7:37 PM, sudarshan.rajagopalan
>> <sudarshan.rajagopalan at vecna.com> wrote:
>>> Just found few function names to be inconsistent towards the naming
>>> convention, and also few API documentation in the RTEMS GPIO files.
>>> Please
>>> commit this if required.
>>> Thanks and Regards,
>>> Sudarshan Rajagopalan
>>> From e17ce266ba4cfaec0159c5477697847629946ced Mon Sep 17 00:00:00
>>> 2001
>>> From: Sudarshan Rajagopalan <sudarshan.rajagopalan at vecna.com>
>>> Date: Mon, 12 Oct 2015 12:47:35 -0400
>>> Subject: [PATCH] Fixes GPIO APIs Naming Convention and Comments
>>>  c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c      |  8 ++++----
>>>  c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c |  4 ++--
>>>  c/src/lib/libbsp/shared/gpio.c                   |  6 +++---
>>>  c/src/lib/libbsp/shared/include/gpio.h           | 20
>>>  4 files changed, 21 insertions(+), 17 deletions(-)
>>> diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>>> b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>>> index 8cf690f..9737dec 100644
>>> --- a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>>> +++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>>> @@ -299,7 +299,7 @@ uint32_t
>>> rtems_gpio_bsp_interrupt_line(rtems_vector_number vector)
>>>    return event_status;
>>> -rtems_status_code rtems_bsp_enable_interrupt(
>>> +rtems_status_code rtems_gpio_bsp_enable_interrupt(
>>>    uint32_t bank,
>>>    uint32_t pin,
>>>    rtems_gpio_interrupt interrupt
>>> @@ -354,7 +354,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
>>>    return RTEMS_SUCCESSFUL;
>>> -rtems_status_code rtems_bsp_disable_interrupt(
>>> +rtems_status_code rtems_gpio_bsp_disable_interrupt(
>>>    uint32_t bank,
>>>    uint32_t pin,
>>> @@ -528,7 +528,7 @@ uint32_t
>>>    return -1;
>>>    uint32_t bank,
>>>    uint32_t pin,
>>> @@ -536,7 +536,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
>>>    return RTEMS_NOT_DEFINED;
>>>    uint32_t bank,
>>>    uint32_t pin,
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
>>> b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
>>> index a782d11..4fb2c93 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
>>> @@ -183,7 +183,7 @@ uint32_t
>>>    uint32_t bank,
>>>    uint32_t pin,
>>> @@ -227,7 +227,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
>>>    uint32_t bank,
>>>    uint32_t pin,
>>> diff --git a/c/src/lib/libbsp/shared/gpio.c
>>> b/c/src/lib/libbsp/shared/gpio.c
>>> index 80e2727..b806556 100644
>>> --- a/c/src/lib/libbsp/shared/gpio.c
>>> +++ b/c/src/lib/libbsp/shared/gpio.c
>>> @@ -1341,7 +1341,7 @@ rtems_status_code rtems_gpio_request_pin(
>>>          return RTEMS_UNSATISFIED;
>>> -      sc = rtems_bsp_select_specific_io(
>>> +      sc = rtems_gpio_bsp_select_specific_io(
>>>               bank,
>>>               pin,
>>>               bsp_data->io_function,
>>> @@ -1805,7 +1805,7 @@ rtems_status_code rtems_gpio_enable_interrupt(
>>> -  sc = rtems_bsp_enable_interrupt(bank, pin, interrupt);
>>> +  sc = rtems_gpio_bsp_enable_interrupt(bank, pin, interrupt);
>>>    if ( sc != RTEMS_SUCCESSFUL ) {
>>>      RELEASE_LOCK(gpio_bank_state[bank].lock);
>>> @@ -1919,7 +1919,7 @@ rtems_status_code
>>> rtems_gpio_disable_interrupt(uint32_t pin_number)
>>>      return RTEMS_NOT_CONFIGURED;
>>> -  sc = rtems_bsp_disable_interrupt(bank, pin,
>>> interrupt_state->active_interrupt);
>>> +  sc = rtems_gpio_bsp_disable_interrupt(bank, pin,
>>> diff --git a/c/src/lib/libbsp/shared/include/gpio.h
>>> b/c/src/lib/libbsp/shared/include/gpio.h
>>> index 54de5f1..7d8f67b 100644
>>> --- a/c/src/lib/libbsp/shared/include/gpio.h
>>> +++ b/c/src/lib/libbsp/shared/include/gpio.h
>>> @@ -736,12 +736,16 @@ extern uint32_t
>>> rtems_gpio_bsp_multi_read(uint32_t
>>> bank, uint32_t bitmask);
>>>   *        does not support the feature, by returning
>>> RTEMS_NOT_DEFINED.
>>>   * @param[in] bank GPIO bank number.
>>> - * @param[in] bitmask Bitmask of GPIO pins to clear in the given
>>> bank.
>>> + * @param[in] pins Array filled with BSP specific pin numbers. All
>>> pins
>>> belong
>>> + *                 to the same select bank.
>>> + * @param[in] pin_count Number of pin configurations in the @var
>>> pins
>>> array.
>>> + * @param[in] arg Pointer to a BSP defined structure with
>>> BSP-specific
>>> + *                data. This field is handled by the BSP.
>>> - * @retval RTEMS_SUCCESSFUL All pins were cleared successfully.
>>> - * @retval RTEMS_NOT_DEFINED The BSP does not support BSP specific
>>> operations
>>> - *                           for groups.
>>> - * @retval RTEMS_UNSATISFIED Could not clear at least one of the
>>> pins.
>>> + * @retval RTEMS_SUCCESSFUL Operation completed with success.
>>> + * @retval RTEMS_NOT_DEFINED Group has no BSP specific pins, or the
>>> BSP
>>> does not
>>> + *                           support BSP specific operations for
>>> groups.
>>> + * @retval RTEMS_UNSATISFIED Could not operate on at least one of
>>> the pins.
>>>  extern rtems_status_code rtems_gpio_bsp_specific_group_operation(
>>>    uint32_t bank,
>>> @@ -859,7 +863,7 @@ extern rtems_status_code
>>> rtems_gpio_bsp_select_output(
>>>   * @retval RTEMS_SUCCESSFUL Function was assigned successfully.
>>>   * @retval RTEMS_UNSATISFIED Could not assign the function to the
>>> pin.
>>> -extern rtems_status_code rtems_bsp_select_specific_io(
>>> +extern rtems_status_code rtems_gpio_bsp_select_specific_io(
>>>    uint32_t bank,
>>>    uint32_t pin,
>>>    uint32_t function,
>>> @@ -918,7 +922,7 @@ extern rtems_vector_number
>>> rtems_gpio_bsp_get_vector(uint32_t bank);
>>>   * @retval RTEMS_SUCCESSFUL Interrupt successfully enabled for this
>>> pin.
>>>   * @retval RTEMS_UNSATISFIED Could not enable the interrupt on the
>>> pin.
>>> -extern rtems_status_code rtems_bsp_enable_interrupt(
>>> +extern rtems_status_code rtems_gpio_bsp_enable_interrupt(
>>>    uint32_t bank,
>>>    uint32_t pin,
>>> @@ -935,7 +939,7 @@ extern rtems_status_code
>>>   * @retval RTEMS_SUCCESSFUL Interrupt successfully disabled for this
>>> pin.
>>>   * @retval RTEMS_UNSATISFIED Could not disable interrupts on this
>>> pin.
>>> -extern rtems_status_code rtems_bsp_disable_interrupt(
>>> +extern rtems_status_code rtems_gpio_bsp_disable_interrupt(
>>>    uint32_t bank,
>>>    uint32_t pin,
>>> 1.9.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
