[PATCH] Fixes GPIO APIs Naming Convention and Comments
Wed Oct 14 22:02:22 UTC 2015
A ticket would be preferred. I didn't notice the attachment. Can you
please (1) make a ticket, (2) close it in the commit message, and (3)
re-send your patch.
Ben, if you get around to it, please commit the revised patch when it
comes through. I'll be away for a few days and unable to commit.
On Wed, Oct 14, 2015 at 5:06 PM, sudarshan.rajagopalan
<sudarshan.rajagopalan at vecna.com> wrote:
> On 2015-10-14 16:28, Gedare Bloom wrote:
>> OK to commit, but the patch did not apply cleanly for me, something
>> wrong with the mail message.
> Hi Gedare,
> The mail message was not sent using git send-email (this is not working for
> us currently), so I copied the contents of the patch to this mail message.
> Could you try using the patch attached in my first mail?
> Also, does this require a ticket?
> Thanks and Regards,
> Sudarshan
>> On Tue, Oct 13, 2015 at 3:11 AM, Ben Gras <beng at shrike-systems.com> wrote:
>>> All,
>>> This change renames these gpio-specific functions:
>>> rtems_bsp_enable_interrupt
>>> rtems_bsp_disable_interrupt
>>> rtems_bsp_select_specific_io
>>> to
>>> rtems_gpio_bsp_enable_interrupt
>>> rtems_gpio_bsp_disable_interrupt
>>> rtems_gpio_bsp_select_specific_io
>>> +1, Definitely an improvement.
>>> On Mon, Oct 12, 2015 at 7:37 PM, sudarshan.rajagopalan
>>>> Just found few function names to be inconsistent towards the naming
>>>> convention, and also few API documentation in the RTEMS GPIO files.
>>>> Please
>>>> commit this if required.
>>>> Thanks and Regards,
>>>> Sudarshan Rajagopalan
>>>> From e17ce266ba4cfaec0159c5477697847629946ced Mon Sep 17 00:00:00 2001
>>>> From: Sudarshan Rajagopalan <sudarshan.rajagopalan at vecna.com>
>>>> Date: Mon, 12 Oct 2015 12:47:35 -0400
>>>> Subject: [PATCH] Fixes GPIO APIs Naming Convention and Comments
>>>>  c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c      |  8 ++++----
>>>>  c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c |  4 ++--
>>>>  c/src/lib/libbsp/shared/gpio.c                   |  6 +++---
>>>>  c/src/lib/libbsp/shared/include/gpio.h           | 20
>>>>  4 files changed, 21 insertions(+), 17 deletions(-)
>>>> diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>>>> b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>>>> index 8cf690f..9737dec 100644
>>>> --- a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>>>> +++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
>>>> @@ -299,7 +299,7 @@ uint32_t
>>>> rtems_gpio_bsp_interrupt_line(rtems_vector_number vector)
>>>>    return event_status;
>>>> -rtems_status_code rtems_bsp_enable_interrupt(
>>>> +rtems_status_code rtems_gpio_bsp_enable_interrupt(
>>>>    uint32_t bank,
>>>>    uint32_t pin,
>>>>    rtems_gpio_interrupt interrupt
>>>> @@ -354,7 +354,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
>>>>    return RTEMS_SUCCESSFUL;
>>>> -rtems_status_code rtems_bsp_disable_interrupt(
>>>> +rtems_status_code rtems_gpio_bsp_disable_interrupt(
>>>>    uint32_t bank,
>>>>    uint32_t pin,
>>>> @@ -528,7 +528,7 @@ uint32_t
>>>>    return -1;
>>>>    uint32_t bank,
>>>>    uint32_t pin,
>>>> @@ -536,7 +536,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
>>>>    return RTEMS_NOT_DEFINED;
>>>>    uint32_t bank,
>>>>    uint32_t pin,
>>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
>>>> b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
>>>> index a782d11..4fb2c93 100644
>>>> --- a/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
>>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c
>>>> @@ -183,7 +183,7 @@ uint32_t
>>>>    uint32_t bank,
>>>>    uint32_t pin,
>>>> @@ -227,7 +227,7 @@ rtems_status_code rtems_bsp_enable_interrupt(
>>>>    uint32_t bank,
>>>>    uint32_t pin,
>>>> diff --git a/c/src/lib/libbsp/shared/gpio.c
>>>> b/c/src/lib/libbsp/shared/gpio.c
>>>> index 80e2727..b806556 100644
>>>> --- a/c/src/lib/libbsp/shared/gpio.c
>>>> +++ b/c/src/lib/libbsp/shared/gpio.c
>>>> @@ -1341,7 +1341,7 @@ rtems_status_code rtems_gpio_request_pin(
>>>>          return RTEMS_UNSATISFIED;
>>>> -      sc = rtems_bsp_select_specific_io(
>>>> +      sc = rtems_gpio_bsp_select_specific_io(
>>>>               bank,
>>>>               pin,
>>>>               bsp_data->io_function,
>>>> @@ -1805,7 +1805,7 @@ rtems_status_code rtems_gpio_enable_interrupt(
>>>> -  sc = rtems_bsp_enable_interrupt(bank, pin, interrupt);
>>>> +  sc = rtems_gpio_bsp_enable_interrupt(bank, pin, interrupt);
>>>>    if ( sc != RTEMS_SUCCESSFUL ) {
>>>>      RELEASE_LOCK(gpio_bank_state[bank].lock);
>>>> @@ -1919,7 +1919,7 @@ rtems_status_code
>>>> rtems_gpio_disable_interrupt(uint32_t pin_number)
>>>>      return RTEMS_NOT_CONFIGURED;
>>>> -  sc = rtems_bsp_disable_interrupt(bank, pin,
>>>> interrupt_state->active_interrupt);
>>>> +  sc = rtems_gpio_bsp_disable_interrupt(bank, pin,
>>>> diff --git a/c/src/lib/libbsp/shared/include/gpio.h
>>>> b/c/src/lib/libbsp/shared/include/gpio.h
>>>> index 54de5f1..7d8f67b 100644
>>>> --- a/c/src/lib/libbsp/shared/include/gpio.h
>>>> +++ b/c/src/lib/libbsp/shared/include/gpio.h
>>>> @@ -736,12 +736,16 @@ extern uint32_t rtems_gpio_bsp_multi_read(uint32_t
>>>> bank, uint32_t bitmask);
>>>>   *        does not support the feature, by returning RTEMS_NOT_DEFINED.
>>>>   * @param[in] bank GPIO bank number.
>>>> - * @param[in] bitmask Bitmask of GPIO pins to clear in the given bank.
>>>> + * @param[in] pins Array filled with BSP specific pin numbers. All pins
>>>> belong
>>>> + *                 to the same select bank.
>>>> + * @param[in] pin_count Number of pin configurations in the @var pins
>>>> array.
>>>> + * @param[in] arg Pointer to a BSP defined structure with BSP-specific
>>>> + *                data. This field is handled by the BSP.
>>>> - * @retval RTEMS_SUCCESSFUL All pins were cleared successfully.
>>>> - * @retval RTEMS_NOT_DEFINED The BSP does not support BSP specific
>>>> operations
>>>> - *                           for groups.
>>>> - * @retval RTEMS_UNSATISFIED Could not clear at least one of the pins.
>>>> + * @retval RTEMS_SUCCESSFUL Operation completed with success.
>>>> + * @retval RTEMS_NOT_DEFINED Group has no BSP specific pins, or the BSP
>>>> does not
>>>> + *                           support BSP specific operations for
>>>> groups.
>>>> + * @retval RTEMS_UNSATISFIED Could not operate on at least one of the
>>>> pins.
>>>>  extern rtems_status_code rtems_gpio_bsp_specific_group_operation(
>>>>    uint32_t bank,
>>>> @@ -859,7 +863,7 @@ extern rtems_status_code
>>>> rtems_gpio_bsp_select_output(
>>>>   * @retval RTEMS_SUCCESSFUL Function was assigned successfully.
>>>>   * @retval RTEMS_UNSATISFIED Could not assign the function to the pin.
>>>> -extern rtems_status_code rtems_bsp_select_specific_io(
>>>> +extern rtems_status_code rtems_gpio_bsp_select_specific_io(
>>>>    uint32_t bank,
>>>>    uint32_t pin,
>>>>    uint32_t function,
>>>> @@ -918,7 +922,7 @@ extern rtems_vector_number
>>>> rtems_gpio_bsp_get_vector(uint32_t bank);
>>>>   * @retval RTEMS_SUCCESSFUL Interrupt successfully enabled for this
>>>> pin.
>>>>   * @retval RTEMS_UNSATISFIED Could not enable the interrupt on the pin.
>>>> -extern rtems_status_code rtems_bsp_enable_interrupt(
>>>> +extern rtems_status_code rtems_gpio_bsp_enable_interrupt(
>>>>    uint32_t bank,
>>>>    uint32_t pin,
>>>> @@ -935,7 +939,7 @@ extern rtems_status_code rtems_bsp_enable_interrupt(
>>>>   * @retval RTEMS_SUCCESSFUL Interrupt successfully disabled for this
>>>> pin.
>>>>   * @retval RTEMS_UNSATISFIED Could not disable interrupts on this pin.
>>>> -extern rtems_status_code rtems_bsp_disable_interrupt(
>>>> +extern rtems_status_code rtems_gpio_bsp_disable_interrupt(
>>>>    uint32_t bank,
>>>>    uint32_t pin,
>>>> 1.9.1
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> devel mailing list
>>> devel at rtems.org
