[rtems commit] libfdt: Initial import
Mon Oct 19 23:04:07 UTC 2015
On 20/10/2015 9:39 am, Joel Sherrill wrote:
> Did I miss all discussion and review of this patch set?
I did not see any discussion on how RTEMS is to use the FDT.
The only patch that appeared was the FDT code itself which I was fine
with as it is a single commit with an import of code. I assumed the
patch was a first stage in a process.
https://lists.rtems.org/pipermail/devel/2015-October/012714.html
I posted some user level code with a possible API to support RTEMS users
but there was nothing more discussed.
