Suggestions for BSPs to Obsolete
Tue Oct 20 11:15:24 UTC 2015
Hallo,
I would remove all 16-bit or less targets.
Maybe we should build a list of BSP directories and find maintainers for
each directory in some time frame. Then remove all BSPs without a
maintainer.
On 14/10/15 02:06, Joel Sherrill wrote:
> Hi
> I am looking for suggestions on BSPs to remove. If you
> have used a BSP in the past but no longer use it, please
> speak up. BSPs with no users are baggage to the project.
> If you have suggestions for other reasons, please speak up
> as well. EOLed boards that no one can have, custom
> variants that are no longer in use, etc.
> Help reduce the maintenance!
> Thanks.
> --joel
> devel mailing list
> devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
