Suggestions for BSPs to Obsolete
Tue Oct 20 13:56:40 UTC 2015
On 10/20/2015 6:15 AM, Sebastian Huber wrote:
> Hallo,
> I would remove all 16-bit or less targets.
I previously posted suggesting the avr, h8300, and m32r be
removed. No one has commented so far.
I want to write two wiki pages as I go. One on removing a
BSP and another on removing an architecture.
> Maybe we should build a list of BSP directories and find maintainers for
> each directory in some time frame. Then remove all BSPs without a
> maintainer.
That is one approach. Another is defining tiers for the BSP
and being more aggressive about dropping them.
I think Chris has discussed his ideas on tiers before.
> On 14/10/15 02:06, Joel Sherrill wrote:
>> Hi
>> I am looking for suggestions on BSPs to remove. If you
>> have used a BSP in the past but no longer use it, please
>> speak up. BSPs with no users are baggage to the project.
>> If you have suggestions for other reasons, please speak up
>> as well. EOLed boards that no one can have, custom
>> variants that are no longer in use, etc.
>> Help reduce the maintenance!
>> Thanks.
>> --joel
>> devel mailing list
>> devel at rtems.org
