or1k C++ was Re: 4.11 Branch BSP C++ Build Issues
Wed Oct 21 21:05:18 UTC 2015
Sorry.. forgot the or1k:
or1k has its own special gcc and (maybe) newlib version.
They are likely out of sync enough to miss the new locking
support.
or1k-rtems4.11-gcc -B../../../../../generic_or1k/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I. -I../../../../../../../rtems/c/src/../../testsuites/samples/hello -I..     -O2 -O0 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o ../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c
mv -f .deps/init.Tpo .deps/init.Po
or1k-rtems4.11-gcc -B../../../../../generic_or1k/lib/ -specs bsp_specs -qrtems -O2 -O0 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs    -O2   -o hello.exe init.o
/data/home/joel/rtems-4.11-work/tools/bin/../lib/gcc/or1k-rtems4.11/4.8.3/../../../../or1k-rtems4.11/lib/libc.a(lib_a-puts.o): In function `_puts_r':
/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/or1k-rtems4.11-gcc-4.8.3-newlib-f296bb3569839b0217ec1a775165d239877e3548-x86_64-linux-gnu-1/build/or1k-rtems4.11/newlib/libc/stdio/../../../../../gcc-4.8.3/newlib/libc/stdio/puts.c:102: undefined reference to `_Mutex_recursive_Release'
/data/home/joel/rtems-4.11-work/rtems-source-builder/rtems/build/or1k-rtems4.11-gcc-4.8.3-newlib-f296bb3569839b0217ec1a775165d239877e3548-x86_64-linux-gnu-1/build/or1k-rtems4.11/newlib/libc/stdio/../../../../../gcc-4.8.3/newlib/libc/stdio/puts.c:99: undefined reference to `_Mutex_recursive_Acquire'
On 10/21/2015 3:52 PM, Daniel Gutson wrote:
> On Wed, Oct 21, 2015 at 3:41 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> lm32, moxie, and nios2 all have generic issues with C++ applications
>> which indicate C++ is not really supported by gcc for these targets.
> Could you please provide more information/details about the error and messages?
> What does "C++ is not really supported" mean? C++ is front-end plus
> the STL, and since
> the front-end is target agnostic, I'm assuming there is some issue with the STL.
>> Would it be OK to disable C++ for those targets?
>> --joel
>> devel mailing list
>> devel at rtems.org
