Per-BSP confdefs (or resource allocation)
Thu Oct 22 05:33:49 UTC 2015
On 21/10/15 21:53, Isaac Gutekunst wrote:
> Hi Devel,
> I looked for a while, but couldn't find a way to specify what
> resources (semaphores, tasks, etc) a BSP requires for an empty project
> (empty Init function).
There is no useful support for this and this is a constant source of
problems.
One way out of this situation would be to use self-contained objects for
the drivers.
> I took a look at this page:
> https://docs.rtems.org/doc-current/share/rtems/html/bsp_howto/Initialization-Code-The-RTEMS-Configuration-Table.html
> but couldn't glean the correct method.
> What is the preferred way to do so?
> Our BSP uses a number of resources for hardware drivers, including
> UART, CAN, SPI, I2C and Ethernet.
In case an empty project includes all these drivers, then something is
wrong with this BSP.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
