[PATCH] [RTEMS] Update RTEMS thread model
Daniel Gutson
daniel.gutson at tallertechnologies.com
Wed Sep 2 15:01:59 UTC 2015
El 2/9/2015 11:58, "Martin Galvan" <martin.galvan at tallertechnologies.com>
escribió:
> On 02/09/2015 15:00, Sebastian Huber wrote:
> > I deleted the test tree. It will take a couple of days before I create a
> > new one. I think it makes more sense if you run the tests yourself, so
> > that you can debug them. I use the realview_pbx_a9_qemu BSP for this,
> > since it is very easy to debug.
> Could you please tell us how to run the tests on realview_pbx_a9_qemu?
> I looked at the READMEs in rtems-testing, but they seem to be quite out
of date.
I assume this is not 'make test', right?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150902/819b1ac7/attachment-0001.html>
