[PATCH] [RTEMS] Update RTEMS thread model
Martin Galvan martin.galvan at tallertechnologies.com
Wed Sep 2 15:04:09 UTC 2015
On Wed, Sep 2, 2015 at 12:01 PM, Daniel Gutson
<daniel.gutson at tallertechnologies.com> wrote:
> El 2/9/2015 11:58, "Martin Galvan" <martin.galvan at tallertechnologies.com>
> escribió:
>> On 02/09/2015 15:00, Sebastian Huber wrote:
>> > I deleted the test tree. It will take a couple of days before I create a
>> > new one. I think it makes more sense if you run the tests yourself, so
>> > that you can debug them. I use the realview_pbx_a9_qemu BSP for this,
>> > since it is very easy to debug.
>> Could you please tell us how to run the tests on realview_pbx_a9_qemu?
>> I looked at the READMEs in rtems-testing, but they seem to be quite out of
>> date.
> I assume this is not 'make test', right?
It's probably make test, but I'm not sure how to let DejaGNU know I'm
pointing at realview_pbx_a9_qemu :)
