[PATCH] [RTEMS] Update RTEMS thread model
Thu Sep 3 05:48:22 UTC 2015
On 02/09/15 16:58, Martin Galvan wrote:
> On 02/09/2015 15:00, Sebastian Huber wrote:
>> I deleted the test tree. It will take a couple of days before I create a
>> new one. I think it makes more sense if you run the tests yourself, so
>> that you can debug them. I use the realview_pbx_a9_qemu BSP for this,
>> since it is very easy to debug.
> Could you please tell us how to run the tests on realview_pbx_a9_qemu?
> I looked at the READMEs in rtems-testing, but they seem to be quite out of date.
I updated the rtems-testing repository.
1. You have to adjust the VERSIONS file.
2. You need the latest Git versions of Newlib, GCC and RTEMS.
3. Use
./do_one -1 -r -g -v -M arm realview_pbx_a9_qemu
to run the GCC tests. Make sure the test runner "realview_pbx_a9_qemu"
works.
4. Use something similar
cd gcc/b-arm-gcc/arm-rtems4.11/libstdc++-v3/testsuite
make check 'RUNTESTFLAGS=  SIM=realview_pbx_a9_qemu
RTEMS_MAKEFILE_PATH=/scratch/git-rtems-testing/gcc/install-git/arm-rtems4.11/realview_pbx_a9_qemu
RTEMS_CONFIG_OBJ=/scratch/git-rtems-testing/gcc/b-arm-gcc/rtems_gcc_main.o
--target_board=rtems-arm-realview_pbx_a9_qemu{-march=armv7-a/-mthumb/-mfpu=neon/-mfloat-abi=hard}'
to run the libstdc++ tests.
You need several development tools on your host.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
