[PATCH] Beaglebone: fix missing clobber in inline assembly.
Thu Sep 10 18:32:29 UTC 2015
Thanks. Should be committed now to 4.11 and master.
On 9/10/2015 1:08 PM, Marcos Díaz wrote:
> Ticket #2416
> https://devel.rtems.org/ticket/2416
> Please let me know if this is ok and if I need to submit something else.
> Greetings
> On Thu, Sep 10, 2015 at 12:48 PM, Joel Sherrill <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     Marco,
>     This looks fine and I will apply it but I want to put it on 4.11
>     and master. Can you file a quick ticket on it?
>     Thanks.
>     --joel
>     On 9/10/2015 10:20 AM, Marcos Diaz wrote:
>         flush_data_cache uses R0 directly but doesn't list it as a clobbered register.
>         Compiling with -O3 made this code break, since the function that calls flush_data_cache
>         already uses r0.
>            c/src/lib/libbsp/arm/beagle/include/bsp.h | 8 +++++++-
>            1 file changed, 7 insertions(+), 1 deletion(-)
>         diff --git a/c/src/lib/libbsp/arm/beagle/include/bsp.h b/c/src/lib/libbsp/arm/beagle/include/bsp.h
>         index 0250749..d9fd2ae 100644
>         --- a/c/src/lib/libbsp/arm/beagle/include/bsp.h
>         +++ b/c/src/lib/libbsp/arm/beagle/include/bsp.h
>         @@ -112,7 +112,13 @@ static inline void isb(void)
>            /* flush data cache */
>            static inline void flush_data_cache(void)
>         -    asm volatile("mov r0, #0; mcr p15, #0, r0, c7, c10, #4" : : : "memory");
>         +    asm volatile(
>         +        "mov r0, #0\n"
>         +        "mcr p15, #0, r0, c7, c10, #4\n"
>         +        : /* No outputs */
>         +        : /* No inputs */
>         +        : "r0","memory"
>            #define __arch_getb(a)      (*(volatile unsigned char *)(a))
>     Joel Sherrill, Ph.D.             Director of Research & Development
>     joel.sherrill at OARcorp.com        On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>     Support Available                (256) 722-9985
> ______________________________
> <http://www.tallertechnologies.com>
> Marcos Díaz
> Software Engineer
> San Lorenzo 47, 3rd Floor, Office 5
> Córdoba, Argentina
> Phone:+54 351 4217888 / +54 351 4218211/ +54 351 7617452
> Skype:markdiaz22
