rtems_set_errno_and_return_minus_one in driver not returning correct value
Inderjit Singh inderjit.singh at aacmicrotec.com
Fri Sep 11 08:10:14 UTC 2015
Hi,
Can I presume that using errno with RTEMS does not work? To me I'm baffled that a RTEMS_SUCCESSFULL value must be returned in order to retain the errno value.
regards,
Indy
________________________________
Sent: 24 August 2015 15:07
To: Chris Johns; devel at rtems.org
Subject: RE: rtems_set_errno_and_return_minus_one in driver not returning correct value
Ok I experimented on and this is what I found out:
This is what I'm doing:
App:
    fd = open(RTEMS_SYSFLASH_DEVICE_NAME, O_RDWR);
    printk("Errno: (%d:%s).", errno, strerror(errno));
    assert(0);
Driver:
rtems_device_driver rtems_sysflash_open(rtems_device_major_number major, rtems_device_minor_number unused, void *args)
    uint32_t result;
    uint32_t status;
    rtems_libio_rw_args_t *rw_args;
    errno = EALREADY;
    return -1;
Printout:
  Errno: (22:Invalid argument).
Now, If I change the return value to RTEMS_SUCCESSFULL in driver like
Driver:
   errno = EALREADY;
   return RTEMS_SUCCESSFULL;
Printout:
   Errno: (120:Socket already connected)
So it seems the one must return RTEMS_SUCCESSFUL to retain the errno value. This is not how it should behave right?
Regards,
Indy
________________________________________
From: devel [devel-bounces at rtems.org] on behalf of Inderjit Singh [inderjit.singh at aacmicrotec.com]
Sent: 24 August 2015 09:08
Hi Chris,
I am pretty sure the driver is working fine yes. I had this issue for some time and ignored the error messages during development as I always get a negative value. Now the driver is working is as it should and I am enforcing the error to test this.
Regards,
Indy
Sent: 24 August 2015 01:19
To: Inderjit Singh; devel at rtems.org
Subject: Re: rtems_set_errno_and_return_minus_one in driver not returning correct value
On 21/08/2015 10:22 pm, Inderjit Singh wrote:
> Hi,
> In my RTEMS driver I set and return error value by following macro:
> rtems_set_errno_and_return_minus_one(EALREADY);
> But in my rtems app when I print the error out by:
> if(fd < 0) {
> printk("Couldn't Open device (%d:%d:%s).", fd, errno, strerror(errno));
> exit(-1);
> *OUTPUT:* Couldn't Open device (-1:22:Invalid argument).
> No matter what errno value i set I always get the same (22: Invalid
> argument). I don't understand why. Any help would be appreciated.
Are you sure the driver is correctly installed and registered and
reaching your code ? Maybe some other part of the file system is
detecting an error and returning the error code you are seeing for some
other reason. I would add a print statement where you set the error code
to see if that code is being reached.
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150911/f3c0d89a/attachment.html>
